Old 04-08-2006, 09:31 PM   #1 (permalink)
Default OpenGl problem
I installed ATI drivers on my FC5 PC. It seems I have no Opengl though. When I open the ati control panel, the opengl version, vendor & renderer are 'unavailable'. As a result I have gfx acceleration. What to do?.
WE ARE THE BORG
YOU WILL BE ASSIMILATED
RESISTANCE IS FUTILE
borg is offline
Old 04-08-2006, 09:40 PM   #2 (permalink)
JGuru's Avatar
Default Re: OpenGl problem
Since the Fedora 5 release is not compatible with third party 3D graphics acceleration
drivers, You should immediately update your Kernel upon installation to get a newer
Kernel that is compatible
Checkout this link for the solution:
http://stanton-finley.net/fedora_cor...es.html#nVidia
Also read this (what RedHat has to say about proprietary Video driver( ATI, NVidia, etc.,):
https://www.redhat.com/archives/fedo.../msg01565.html
JGuru is offline
Old 04-08-2006, 09:59 PM   #3 (permalink)
I have a fully updated kernel. I cannot update it to anything newer.
WE ARE THE BORG
borg is offline
Old 04-08-2006, 10:04 PM   #4 (permalink)
JGuru's Avatar
For ATI Graphics card, Open the Terminal Window & login as Root:
$ su -
(Enter password)
$ yum -y --enablerepo livna install kmod-fglrx
(Hit Enter key & wait for the installation to complete)
Read this link for more details!!: (It also contains instructions for ATI Graphic cards!!)
JGuru is offline
Old 05-08-2006, 08:16 AM   #5 (permalink)
Thats exactly what I did. The drivers got installed, but I have no OpenGL. This is kinda strange. Maybe I will try uninstalling & reinstalling the damn thing. Any other suggestions?.
WE ARE THE BORG
borg is offline
