Old 01-08-2006, 04:31 PM   #1 (permalink)
Default Flashplayer problems
Guys, I am on FC5 with Firefox 1.5.0.5. Am having some issues with flashplayer 7. I downloaded flashplayer & copied the two files required files in the firefox's pulgins folder. But it isn't working for some reason. I see blank space in place where I should be seeing flash animation. I don't get a prompt to install flashplayer either. What seems to be the issue?.
WE ARE THE BORG
YOU WILL BE ASSIMILATED
RESISTANCE IS FUTILE
borg is offline
Old 01-08-2006, 04:38 PM   #2 (permalink)
Venom's Avatar
Default Re: Flashplayer problems
http://www.stanton-finley.net/fedora...tes.html#Flash
Just follow this.
Venom is offline
Old 01-08-2006, 04:38 PM   #3 (permalink)
JGuru's Avatar
If you have installed AdBlock extension for FireFox browser then Flash animations
won't show up!! See the following link for installing Flash in Fedora 5:
http://stanton-finley.net/fedora_cor...ion_notes.html
I had already given this in the 'One Stop Reference for enabling Multimedia in Linux'
JGuru is offline
Old 01-08-2006, 04:39 PM   #4 (permalink)
Venom's Avatar
Not necessary, that is only if you manually block all *.swf's
Venom is offline
Old 01-08-2006, 06:17 PM   #5 (permalink)
Thabks guys. The problem was with the SELinux settings. never faced this kind of problem before.
WE ARE THE BORG
borg is offline
