26-07-2006, 12:45 PM
Location: If I had a webcam u could have seen me, before your eyes.
how to shutdown...
sob..... i started using linux recently..... the suse (one of the slightely older dunno which) and am totaly new to it.... can anyone tell me how to shutdown?????? in the start button there is only log off......whuch returns me to the log in screen ..not shutdown....plz help i have to press the power button on the cpu to turn off.......Helppppppppppppppppppp..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
26-07-2006, 12:49 PM
Level 96 Headbanger
Re: how to shutdown...
AFAIK, the log out option in the launch menu is the only way you can shutdown a KDE run Linux machine. Look carefully and you should find the options to shutdown, Restart and Log off.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 ( New :twisted:), Roland MicroCube Amp.
26-07-2006, 01:43 PM
String Phreak
Hmmm...power button is for emergency. SHuts down the machine when the system is heavily loaded and is not responding quickly.
Neways logoff takes u to shutdown menu!! To shutdown open root terminal and write " shutdown -h now ". Ur done !!
To restart type "shutdown -r now"!
Problem solved!!
26-07-2006, 01:58 PM
18 Till I Die............
Also when you come to the login screen. Check the bottom part. There should be Shutdown/Reboot/ or some such options. Just explore a bit you should find it.
http://www.bash.org/?258908
Microsoft MVP
On the Login Screen, u should get the shutdown menu, like "System menu" or something like that.
26-07-2006, 02:09 PM
Google Bot
or open terminal... then type 'init 0'
Reason: Automerged Doublepost
26-07-2006, 04:20 PM
for shut down in cli mode init 0 and
what is the command for restart ?
init ???
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
26-07-2006, 04:32 PM
Google Bot
i think its init 6
26-07-2006, 06:31 PM
In Pursuit of "Happyness"
Yeah init 6 is for reboot.
27-07-2006, 07:41 PM
Is it possible that we directly get all options(Restart/shutdown/logoff) to choose when we click logout ,
I suppose that it is possible but dunno how to do it....
Kubuntu has similar thing,
geeks out here find how to do that....
27-07-2006, 08:08 PM
Google Bot
i think its in mandrake 10.1
27-07-2006, 08:23 PM
@pathiks: I hope that wudnt be changing to Mandriva for this thing...
If any body knows hot to add that option in kmemu itself, plz post...
27-07-2006, 08:33 PM
Google Bot
i told mandrake....
27-07-2006, 09:45 PM
Open the Terminal Window and type:
First login as Root
$ su -
(Enter password )
$ telinit 0
(ie., telinit followed by zero '0')
Press the Enter key.
This will shutdown your Suse Linux O.S. This will work in any Linux!!
Similarly 'telinit 6' will reboot your System (similar to 'reboot' command).
28-07-2006, 12:55 AM
El mooooo
The problem here is that you guys are either not using a display manager or using something other than KDM. For the shutdown options to appear under KDE logoff screen, you people HAVE to use KDM with KDE. You cannot use GDM, XDM (or any other display manager) and get the shutdown options.
If you use GDM and KDE then the only "graphical" way to shutdown is to return to display manager and shutdown from there. Oh and please don't use the power button, you will corrupt your file system and screw the whole OS.
28-07-2006, 02:25 PM
@pathiks: dear lad Mandrake is now Mandriva.....plz hinder posting msg which are more like sms and that too of nobody's help....
@jguru: u didn't get me....the answer u gave has already been given by many people see kalpik's and all....
@eddie: Yes u are right i am using gdm right now, but don't know how to use KDM as my display manager....Can u tell me that....
In which conf file i have to make changes...
Thanks in Advance.
