Old 25-07-2006, 11:57 PM   #1 (permalink)
Unhappy Hard disk LED keeps on glowing
Hi all,
I am using Fedora core 3 the problem is sometime my system getting hang and my harddisk LED keeps on glowing .
I am using XFCE(4.0.2) .Occasionally GNOME .
My Processer is AMD Athlon 783 MHZ.
What is the problem ? please tell me how to resolve it .
One more question .
Is there any program for Linux to check the harddisk ?
Thanks
m.parthiban is offline
Old 26-07-2006, 12:43 AM   #2 (permalink)
rahul_becks23's Avatar
Default Re: Hard disk LED keeps on glowing
ur processor is a slow one...so it comes on FULL load when there r too many processes...and LED continuosly glows then...u have to wait for the processes to end...if they r too high...then ur computer will hang.
Get a fast processor.
rahul_becks23 is offline
Old 26-07-2006, 12:50 AM   #3 (permalink)
JGuru's Avatar
It maybe due to a virus. The virus reads/writes to the harddisk and corrupts the O.S.
You said that your O.S hangs. I definitely suspect a virus in your System.
JGuru is offline
Old 26-07-2006, 12:55 AM   #4 (permalink)
maybe a virus....but in linux...very rare...but i still recommend that u check over by an anti-virus.
Old 26-07-2006, 04:15 AM   #5 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Hard disk LED keeps on glowing
try booting in command line...check whether it hangs...if it works better in cmdline,then its sure that procee cant handle that much..may be u can add a little more memory...virus in linux chancei illai!
praka123 is offline
