Old 21-07-2006, 05:17 PM   #1 (permalink)
Default Help me with USB Modem use at linux
I have been using airtelbroadband with USB modem zyxel model prestige 600 series.............Dose these modem were accpeted in linux if so which linux accepts fedro or redhat????
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 21-07-2006, 06:02 PM   #2 (permalink)
Venom's Avatar
Default Re: Help me with USB Modem use at linux
http://eciadsl.flashtux.org/ see if this supports it... else no
Venom is offline
Old 27-07-2006, 08:46 AM   #3 (permalink)
can u help how to install with it??
rajas700 is offline
Old 27-07-2006, 10:42 AM   #4 (permalink)
18 Till I Die............
Download the FC rpm from here http://eciadsl.flashtux.org/download.php and install it using command
 rpm -ivh <filename>
Don't know how to configure the connection after that. Someone using Airtel maybe able to help further.
http://www.bash.org/?258908
mehulved is offline
Old 27-07-2006, 11:00 AM   #5 (permalink)
JGuru's Avatar
Suse 10.1 supports USB modems. I have tested one USB modem with Suse , it
detected it & also after configuring it I was able to connect to the Net.
Forget RedHat, it's Fedora now, RedHat only concentrates on the Enterprise segment.
First try with Fedora 5 , download the drivers & install them as @Tech_your_future
has suggested. See if it works. Otherwise try with Suse 10.1.
JGuru is offline
