Hi!
I´m using Fedora Core 5(64-bit) with kernel version 2.6.15-1.2054 on my system with the following configuration.
AMD Athlon 64 3200+ (Venice Core)
MSI RS-480M2 motherboard
512 MB DDR RAM
160GB SATA Seagate harddrive
I tried to install the Linux driver for the modem DFM-560IS+++ on this configuration. The modem works absolutely fine with Windows 98/XP. Below is the log of the problem facing by me. Hope you can help me out.
__________________________________________________ ___________________________
(1) Installing through the *.rpm available on the CD didn´t work fine, so used the *.tar.gz package to install. Below is the installation instruction notes given on the CD and followed exactly by me.
If you have obtained the driver package in tar format:
1. extract the package with "tar -xzf hsflinmodem-<version>.tar.gz"
2. change to the package directory with "cd hsflinmodem-<version>"
3. run "make install" from the top of the package directory.
4. run "hsfconfig" to complete the installation and configure your modem.
(Alternatively to this whole procedure you may generate RPMS from the tar
package using rpm -ta hsflinmodem-<version>.tar.gz")
(2)Below is the installation which followed after typing the command:
[root@localhost hsflinmodem-4.06.06.02]# make install
make[1]: Entering directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/inf'
install -m 644 linux_athens.inf linux_hsfi.inf linux_hsf.inf linux_intel_smartmc.inf linux_smarthsf.inf /etc/hsf/inf
make[1]: Leaving directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/inf'
make[1]: Entering directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/inf2bin'
cc -I../imported/include -I../modules/osspec/include -DFRAME_WORK=FWK_LINUX_SOFTK56 -DFRAME_WORK_IMPORTED -DOVERRIDE_NEW=1 -DPORTABILITY=0 -DMULTYDP -DHSFLINUXVERSION="\"4.06.06.02\"" -O2 -Wall -c -o inf2bin.o inf2bin.c
inf2bin.c: In function ‘ProcessString’:
inf2bin.c:230: warning: pointer targets in assignment differ in signedness
inf2bin.c: In function ‘ProcessCtryStruct’:
inf2bin.c:387: warning: pointer targets in assignment differ in signedness
cc -o hsfinf2bin inf2bin.o
install -m 755 hsfinf2bin /usr/sbin/hsfinf2bin
make[1]: Leaving directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/inf2bin'
make[1]: Entering directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/firm2bin'
cc -I../imported/include -I../modules/osspec/include -DFRAME_WORK=FWK_LINUX_SOFTK56 -DFRAME_WORK_IMPORTED -DOVERRIDE_NEW=1 -DPORTABILITY=0 -DMULTYDP -O2 -Wall -c -o firm2bin.o firm2bin.c
cc -o hsffirm2bin firm2bin.o
install -m 755 hsffirm2bin /usr/sbin/hsffirm2bin
install -m 644 cnxykf.hex /etc/hsf
make[1]: Leaving directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/firm2bin'
make[1]: Entering directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/scripts'
sed \
-e 's!@PREFIX@!/usr!g' \
-e 's!@HSFETCDIR@!/etc/hsf!g' \
-e 's!@HSFLIBDIR@!/usr/lib/hsf!g' \
-e 's!@HSFINFDIR@!/etc/hsf/inf!g' \
-e 's!@HSFSERIALMINOR@!64!g' \
-e 's!@HSFBININF_FILE@!/etc/hsf/nvram.bin!g' \
-e 's!@HSFFIRMWR_FILE@!/etc/hsf/firmware.bin!g' \
-e 's!@HSFLINUXVERSION@!4.06.06.02!g' \
< hsfconfig.in > hsfconfig
chmod 755 hsfconfig
install -m 755 hsfconfig hsfstop /usr/sbin
install -m 755 hsfsysid /usr/bin
make[1]: Leaving directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/scripts'
cc1: error: /usr/src/linux/include/linux/config.h: No such file or directory
cc1: error: /usr/src/linux/include/linux/version.h: No such file or directory
make[1]: Entering directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/modules'
rm -rf "/usr/lib/hsf/config.mak" "/usr/lib/hsf/imported" "/usr/lib/hsf/modules"
mkdir -m 755 -p /usr/lib/hsf/modules
(cd .. && find config.mak imported -depth -print | cpio -pdm /usr/lib/hsf)
3664 blocks
find . \( -name '*.[ch]' -o -name '*.mak' -o -name '[Mm]akefile' \) -print | cpio -pdm /usr/lib/hsf/modules
558 blocks
find binaries -depth -print | cpio -pdm /usr/lib/hsf/modules
0 blocks
make[1]: Leaving directory `/root/Desktop/Applications,patches/Dialupmodemdriver/hsflinmodem-4.06.06.02/modules'
install -m 444 LICENSE /usr/lib/hsf
(3) After the installation, we require to type ¨hsfconfig¨ command to configure the modem. But, I get the error message which I post below.
[root@localhost hsflinmodem-4.06.06.02]# hsfconfig
Linux HSF softmodem drivers, version 4.06.06.02
grep: /proc/ksyms: No such file or directory
/usr/bin/hsfsysid: line 99: [: too many arguments
HSF drivers currently don't support SMP (Symmetric Multi-Processing) kernels.
First, ensure that the proper kernel source and compiler packages
from your distribution vendor and/or the community are installed.
The Linux kernel can then be reconfigured by running "make menuconfig"
under the kernel source directory (usually /usr/src/linux).
Verify that the proper options for your system are selected,
and that CONFIG_SMP ("Symmetric multi-processing support" under
"Processor type and features") is disabled, as this driver is
presently designed to work on single-processor machines.
Then compile and install your new kernel (for more information aboutthis procedure, see the README file under the kernel source directory),
reboot the system using the new kernel, and re-run "hsfconfig".
Please tell me if I´m going wrong somewhere, else if there is anything wrong with the package or the OS.
