Old 07-07-2006, 09:02 PM   #1 (permalink)
Question What are file system magic numbers?
I searched google and found some results , but it seems to be too much complicated. Can anyone explain it simply for me? Thanks in advance.
vinayasurya is offline
Old 07-07-2006, 09:46 PM   #2 (permalink)
JGuru's Avatar
Default Re: What are file system magic numbers?
The magic numbers are number formats that make the File System understand
what type of file it is. For eg., JPEG Image files begin with 0xFFD8FF. MIDI files begin
with 'MThd' (0x4D546864). PostScript files start with '%!'(0x2521). And this is how
the O.S understands & deciphers what type of file it is!!
Read more about it :
http://en.wikipedia.org/wiki/Magic_number_(programming)
JGuru is offline
Old 07-07-2006, 11:35 PM   #3 (permalink)
Is that only for linux like file systems or FAT32 has the same?
Old 07-07-2006, 11:46 PM   #4 (permalink)
JGuru's Avatar
That applies to all Operating Systems. They have their own way of treating things.
The JPEG image you save in Windows can be viewed in Linux. Windows follows
the FAT (File Allocation Table) File System and NT follows NTFS. Linux follows the ext3
( Journaling File System).
JGuru is offline
Old 08-07-2006, 09:11 AM   #5 (permalink)
blackleopard92's Avatar
one thing.Is ext3 file system accessible from Windows?it doesn't seem to me.
blackleopard92 is offline
Old 08-07-2006, 11:19 AM   #6 (permalink)
Beware of the innocent
ilugd's Avatar
no leopard, but fat is accessible from both.
ilugd is offline
Old 08-07-2006, 11:20 AM   #7 (permalink)
18 Till I Die............
@blackleopard you need extra tools like explore2fs or something else.
http://www.bash.org/?258908
mehulved is offline
Old 08-07-2006, 02:12 PM   #8 (permalink)
FooBar Guy
GNUrag's Avatar
You might want to try this:
http://db.glug-bom.org/lug-authors/a...s-1.00pre6.zip
http://web.gnuer.org
GNUrag is offline
Old 08-07-2006, 02:47 PM   #9 (permalink)
dIgItaL_BrAt's Avatar
This driver allows you to access ext2/ext3 drives from explorer,just like any other drive.
http://www.fs-driver.org/
dIgItaL_BrAt is offline
