Old 28-06-2006, 12:23 AM   #1 (permalink)
String Phreak
mediator's Avatar
Default Limewire workaround FC5 ??
Hi,
I had limewire on FC4, and I had installed java 1.4.2 manually on it then! Now FC5 comes preloaded with java development kit (JDK).....and i can compile java programs and run them.
The version is 1.4.2. But installing limewire it says java 1.4.1 is needed as dependency.
I dont wanna install java manually again. Can the existing java be used for limewire install somehow?
mediator is offline
Old 28-06-2006, 12:28 AM   #2 (permalink)
18 Till I Die............
Default Re: Limewire workaround FC5 ??
See this has been posted before too. You forgot to search.
If it's a rpm of limewire just pass --nodeps option to it
rpm -ivh --nodeps <filename>
mehulved is offline
Old 28-06-2006, 02:07 PM   #3 (permalink)
String Phreak
mediator's Avatar
Yea Sorry.......Neways Thanx for replying , I had found the solution maself too!
mediator is offline
