I'm completely new to linux and have installed fedora core 4.
I have a smart link 56k dialup modem from krypton and it is working fine in windows xp. I'm not able to install its drivers in linux.
At first I used the driver provided by the manufacturer (slmdm-2.7.14). I extracted the contents of the TAR archive, entered the extracted dir and typed in make. The terminal reported errors in every line.
Then I downloaded two drivers, a source RPM and another TAR archive.
I don't know how to install using source RPM.
I extracted the new TAR archive, entered the extracted directory and gave the make command. The make command is giving me an error stating, file driver/.amrmo.o.cmd not found for driver/amrmo.o. I'm not able to figure out what the problem is, and its solution.
can anybody help me, please? And also tell me what to do with the source RPM
