Old 21-06-2006, 11:00 PM   #1 (permalink)
The Linux Man !
paragkalra's Avatar
Question 32 bit Linux VS 64 bit AMD
Hi everyone,
Can I install 32 bit Suse 10 Linux on 64 bit AMD Machine?
If yes, Well and Good.
If Not, then what to do?
Parag.A.Kalra, The Linux Man
http://www.paragkalra.com/
In this world without WALLS and GATES who need WINDOWS! USE LINUX! STOP PIRACY! GO OPEN SOURCE!
paragkalra is offline
Old 22-06-2006, 12:37 AM   #2 (permalink)
JGuru's Avatar
Default Re: 32 bit Linux VS 64 bit AMD
Yes, ofcourse you can. It will definitely work. But since your machine is having 64-bit
architecture , it won't be properly utilised. So the speed burst and other things that
come with 64-bit machine will be absent!! To make full use of your machine you
must install 64-bit OS. In this case Suse 10 64-bit.
JGuru is offline
Old 22-06-2006, 02:59 AM   #3 (permalink)
thunderbird.117
Posts: n/a
your topic is bit misguided. I thought 32bit linux is challenging 64bit AMD.
