Old 13-06-2006, 02:14 PM   #1 (permalink)
56561's Avatar
Thumbs up whats the difference between Xantos,linspire with linux
I am a newbie . I heard about LINUX operating system that it has different types like SUSE, redhat , fedora , ubuntu ? whats the difference between all these ? and there are something which is combination of windows and linux like lindos , linspire and xantos? whats the advantage of using lindows than a original linux?
56561 is offline
Old 13-06-2006, 02:23 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: whats the difference between Xantos,linspire with linux
The basic difference is the Package Managers they use. Red Hat/Fedora and some others use the RPM (RH Package Manager) where as Ubuntu, SuSe, etc use DEB (Debian Package Managers)
Apart from this I guess there are other vital diffrences too, maybe some guru will answer it later here
Harsh J
www.harshj.com
QwertyManiac is offline
Old 14-06-2006, 11:09 AM   #3 (permalink)
JGuru's Avatar
Qwerty, you are wrong !! Suse also uses RPM format!! Ubuntu, Knoppix are based on Debian. Debian is more secure. You can try Ubuntu if you want. Anyway your question must be posted in the 'Open Source' section!!! Don't do this mistake again.
JGuru is offline
Old 14-06-2006, 01:34 PM   #4 (permalink)
56561's Avatar
I have asked a question thats why I put it in the open-source section , however I think lindos , linspire and xantos are not free so why it will go to the open source section?
56561 is offline
Old 14-06-2006, 02:12 PM   #5 (permalink)
The Researcher
As per my knowledge and experience with these distros, I have found the packages (different software for different uses) different.
Ramakrishnan is offline
Old 15-06-2006, 07:51 PM   #6 (permalink)
vignesh's Avatar
They have free versions as well... Freespire and Xandros open circulation.
vignesh is offline
Old 16-06-2006, 01:09 AM   #7 (permalink)
Problem with linux is installation of new softwares........is there any way so we can install linux softwares easily like windows..........means just click setup and then next ...i accept.....next......finished........
mkmkmk is offline
