Old 10-06-2006, 08:17 PM   #1 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
Question CDs from DVD ???
im sorry and neithr did i wnated 2 make double threadz on a sm topic.. but in case...
How can i create a set of cds frm a dvd???
to add 2 it.. hw can i do the sm with fedora core dvds???
aku is offline
Old 10-06-2006, 08:44 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: CDs from DVD ???
I tried it.. There is a way (or so they say), but the CD's didnt work.. This method uses jigdo..
kalpik is offline
Old 11-06-2006, 12:31 AM   #3 (permalink)
JGuru's Avatar
Yes there is a way. But it's only for experts, not for normal users.
Normal users are better off burning CD images to CD.
JGuru is offline
Old 11-06-2006, 08:32 AM   #4 (permalink)
aku
Gonna make it BiG
aku's Avatar
hmm.. kalpic.. can u pls explain it a bit more???
aku is offline
Old 11-06-2006, 12:17 PM   #5 (permalink)
JGuru's Avatar
If you have 5 CDs of Suse Linux you can make it into a DVD. Here is the procedure:
http://en.opensuse.org/Making_a_DVD_from_CDs
JGuru is offline
Old 11-06-2006, 01:35 PM   #6 (permalink)
kalpik's Avatar
Download the fedora core 5 .jigdo and .template files for all 5 CDs from http://download.wpi.edu/pub/jigdo/ . Then install jigdo by typing "yum install jigdo" now just type "jigdo-lite <path to FC5disk1.jigdo file" it will ask you the location of DVD drive eg "/media/disk-1". Jigdo will then create the iso files. Do the same for each of the 5 CDs.
P.S: Im saying again, it didnt work for me, the installation failed.
kalpik is offline
Old 12-06-2006, 12:03 AM   #7 (permalink)
aku
Gonna make it BiG
aku's Avatar
okay.. interestin.... btw Jguru.. i kno dat.. i jus wanna kno da rev. process.
newayz kapik.. tx dude
aku is offline
Old 13-06-2006, 11:49 AM   #8 (permalink)
aku
Gonna make it BiG
aku's Avatar
well wat i ws thinkin is dat.. we r havin da dvd image of da distro.. nw is there ne way 2 extract da images fr da consicutive cds frm da dvd source using da md5 hash??? of lyk theres a script which will extrace all the files frm da iso, create seperate folders and then da respective directory structures for thr respective cds.. adn later on it'll convert it 2 a iso and we'll b abl 2 burn it.. i hope ive made myself clear... 8)
aku is offline
