Old 10-06-2006, 04:27 PM   #1 (permalink)
Default mt882 using yast 2
hi guys
have any of tried configure bsnl modem using yast 2(suse10.0)?
I tired it but with little success.
i copied the settings of the 'ipconfig /all' in windows to yast
ping command did not work.
ifconfig doesnot contain eth0
thanking you chintan
chintanraoh is offline
Old 10-06-2006, 06:44 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: mt882 using yast 2
USB or LAN?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-06-2006, 06:37 AM   #3 (permalink)
usb
Old 11-06-2006, 07:36 AM   #4 (permalink)
Commander in Chief
Then forget it, its impossible atm...
Harsh J
www.harshj.com
Old 11-06-2006, 12:01 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
get a lan card just for 150-175rs then it is work of breeze else u have to do a little reseach yourself.
@qwerty
it is possible but is really difficult
gary4gar is offline
Old 11-06-2006, 12:16 PM   #6 (permalink)
Commander in Chief
Ok tell me the way if you have discovered it! I didnt say its completely impossible. Just at the moment its not yet known how to config it or other unrecognized USB devices (on new distros)
Harsh J
www.harshj.com
Old 15-06-2006, 01:39 PM   #7 (permalink)
tell about LAN. I have SuSE 10 & UT-300R2 modem
P4 2.4 GHz Prescott;768 MB RAM;Seagate 80 GB PATA & 160 GB SATA;Creative Inspire 5200;ViewSonic E71f;256 MB Leadtek A6600TD;Logitech MX518;Microsoft Natural Ergonomic 4000
cyberzook is offline
Old 15-06-2006, 01:53 PM   #8 (permalink)
Commander in Chief
Follow this
[Tutorial] Configuring an Always On DataOne on gnu/Linux
[But I just enabled DHCP and it auto configured the whole net for me ]
Harsh J
www.harshj.com
Old 15-06-2006, 02:57 PM   #9 (permalink)
I dont want an "always on" connection
Old 15-06-2006, 04:54 PM   #10 (permalink)
JGuru's Avatar
Even Ubuntu uses DHCP and automatically configures. No need to provide
IP address , subnet mask etc., Cyberzook, if you don't want an always on Net
connection, just disconnect the cable jack. That solves your problem.
JGuru is offline
Old 23-06-2006, 11:52 AM   #11 (permalink)
Commander in Chief
good solution JGuru
I think KPPPoE or something helps in dial up type connections...
Harsh J
www.harshj.com
