Old 06-06-2006, 05:23 PM   #1 (permalink)
Question what is difference between redhat based, Debian, Slackware based linux?
What is actual difference between redhat, Debian, Slackware linux? Especailly from a users point of view. Is there any difference, Will rpm works on all three? Are there any common software packages like rpm for other flavours of Linux?
vinayasurya is offline
Old 06-06-2006, 07:32 PM   #2 (permalink)
vignesh's Avatar
Default Re: what is difference between redhat based, Debian, Slackware based linux?
All have different package management systems...
vignesh is offline
Old 06-06-2006, 08:13 PM   #3 (permalink)
18 Till I Die............
Well as the name says.
Red Hat based distros use Red Hat's package Manager i.e. rpm.
Debian based distros use Debain's package Manager i.e. deb.
Slackware based distros use Slackware's package management system i.e. tgz.
Well the end user will be better off using native package for each type of distro. For example it is more recommendable to use deb files than rpm files for Ubuntu, which is based on debian. But, first you should look forward to package specifically compiled for that distro eg. It is favourable to use a deb file compiled for Ubuntu 6.06 then using deb file compiled for Debian 3.1, if you are using Ubuntu 6.06.
Yes rpm will work on all three but you shouldn't use it unless you have no other alternative which is a rare case.
mehulved is offline
Old 07-06-2006, 02:17 PM   #4 (permalink)
Is there any common standard between these distros? Do all the linux have same working principles and implementation inside?
Old 07-06-2006, 04:56 PM   #5 (permalink)
vignesh's Avatar
YUp... The companies can have some extra commands and scripts created but in general they are all same... Eg redhat-system-config-users in REdhat is
users-admin in Ubuntu ... All linux distros all vary in that.. If you are using GUI.. you won`t notice that....
vignesh is offline
Old 07-06-2006, 08:06 PM   #6 (permalink)
Question Re: what is difference between redhat based, Debian, Slackware based linux?
I heard from somewhere that boot process of Debian is different from Redhat. Is it true?
Old 07-06-2006, 08:22 PM   #7 (permalink)
Well it is somewhat different but as a end user you won't realise much until you really dig deep into the process and how it goes. So, you need not worry much.
In linux everything can differ cos linux always gives lots of choices for everything.
mehulved is offline
Old 07-06-2006, 08:42 PM   #8 (permalink)
left this forum longback
praka123's Avatar
Smile Re: what is difference between redhat based, Debian, Slackware based linux?
AFAIK,Debian/Ubuntu is superior compared to other distro's due to their use of dpkg/apt package management system.
praka123 is offline
Old 08-06-2006, 10:00 PM   #9 (permalink)
Why everyone says that deb packages are better than rpms? Also can anyone suggest one or websites for rpm and deb downloads. I don't have internet connection in Linux so i have to download from windows and apply in Linux, so automated package installation will not work.
Old 08-06-2006, 10:38 PM   #10 (permalink)
Commander in Chief
QwertyManiac's Avatar
manually installing packages is hell... its better to have a net connection and use apt-get or yum to install...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-06-2006, 11:24 AM   #11 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Me too facing the same prb!
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 10-06-2006, 03:47 PM   #12 (permalink)
Then you'll will have to find all the dependancies of the software. Then see how many are present on your system. Are their versions proper. There's no conflict of dependancies. Also, all software needs to be from 1 place. Mixing softwares from different sources will totally mess up your system.
So, you will need to follow the above and then you can install the apps manually.
mehulved is offline
Old 11-06-2006, 09:16 PM   #13 (permalink)
Satissh S's Avatar
IMHO I would classify distro's into two manners
1. Source
2. Binary
I dont think its a matter of debian is better than RH (it is though ) but generally i would prefer and iam using a source based distro. Why would u want to use stuff which someone else has bordered for you??
This is a free world, u want some free software?? download the source and build it for your machine. Make it for your machine. Make it work better. And this is basically the differences between distro's.
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 09-07-2008, 12:11 PM   #14 (permalink)
cooldude666666's Avatar
Talking Re: what is difference between redhat based, Debian, Slackware based linux?
I too think this is the best way to install software. And as far as my experience goes(I don't have much), installing from source is just a matter of ./configure, make and make install. And at times you would need to make some changes in some configuration files but that too is easy as its all documented. And it really is As Easy As Saying This!
Keeping it Posted!!!!!!!!!
cooldude666666 is offline
Old 09-07-2008, 01:05 PM   #15 (permalink)
in search of myself
CadCrazy's Avatar
Lol BUMP of the year award
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga"
CadCrazy is offline
Old 09-07-2008, 01:09 PM   #16 (permalink)
Pat
Member of Apple Family
Pat's Avatar
I dont see the point in bumping such an old thread. Talking about this issue, not everyone has time/patience to compile everything from source. Secondly its not as easy as you make it sound. You need to have all the needed libraries and dependencies installed on your system in order for the app to compile correctly
Pat is offline
Old 09-07-2008, 01:19 PM   #17 (permalink)
Always confused
vamsi360's Avatar
Post Re: what is difference between redhat based, Debian, Slackware based linux?
debian .deb
redhat .rpm
We have to install seperate binaries in Ubuntu to install rpm packages.We cannnot install them directly.
Instead we can use targz or tarbz2 source codes which come with all dependencies and also work on almost every linux distribution on earth
vamsi360 is offline
Old 09-07-2008, 01:29 PM   #18 (permalink)
Pat
Pat's Avatar
Originally Posted by vamsi360 View Post
debian .deb
redhat .rpm
Instead we can use targz or tarbz2 packages which work on almost every linux distribution on earth
Whats with the fonts dude ? Anyways, tgz and bz etc. are not packages, they are source-codes that you need to compile in order to be able to use the app. Please refer to my previos post for the problems with compiling from source.
Pat is offline
Old 09-07-2008, 01:33 PM   #19 (permalink)
Think Zen.
ray|raven's Avatar
As it so happens , tgz is also the same extension used by slackware packages.
Oh n btw , why'd u guys bump a ~2 year old thread again?
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 09-07-2008, 01:34 PM   #20 (permalink)
Always confused
vamsi360's Avatar
For Ubuntu u can visit packages.ubuntu.com and get every software available and compiled for ubuntu.But the problem is that u have to find the correct dependencies.There is a trick.When u are downloading for example vlc player deb package other similar packages are also listed.Then u download the others also along with it.Mostly this works but u may get frustrated like me as i used to in my earlier days.So be patient when u dont get a net connection for ubuntu.It is adviceble to get a net connection with ubuntu.
UF you want a complete full linux distro that contain every codecs and every drivers that are not free go for mandriva One or PCLinuxOS 2007.These are very best for beginners.
tarbz2 are source codes.I apolozize,but we can easily compile them on any linux distro.
yeah...........very old thread.Even the owner would have forgotten it
vamsi360 is offline
Old 09-07-2008, 05:16 PM   #21 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Lol @ bump !
PCLinux and mandriva one has all codecs preinstalled?
FilledVoid is offline
Old 09-07-2008, 05:21 PM   #22 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Originally Posted by FilledVoid View Post
Lol @ bump !
I seriously doubt it.
Mint is the way to go if you are looking at propiatary compatibility and are a newbie.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 09-07-2008, 05:24 PM   #23 (permalink)
Pat
Pat's Avatar
Lol @ bump !
AFA PCLinuxOS is concerned, it bundles not all, but definitely more codecs than are available on a default Ubuntu install,for example. I dont think thats the case with Mandriva though!
+1
Pat is offline
Old 09-07-2008, 05:39 PM   #24 (permalink)
adi007's Avatar
I have seen other forum's which will archive the threads and posts after certain time and no one can post that...
why their is no such facility here..?
As a result some people who come across such threads via search will just post and bump the thread
☼ onlyfreewares.info ► Onlyfreewares...Nothing Else !!
☼ regtweak.info ► Windows Registry hacks and tricks
☼ blog.aditech.info ► There is something for everyone
adi007 is offline
Old 09-07-2008, 06:05 PM   #25 (permalink)
hullap's Avatar
i dont get it,
what do u guys get by bumping threads?
hullap is offline
Old 09-07-2008, 06:07 PM   #26 (permalink)
The Smaller Bang
some threads, like these, are still valid.
Old 10-07-2008, 01:22 PM   #27 (permalink)
Always confused
vamsi360's Avatar
PCLinuxOS,Mint and Mandriva one come with almost ever codecs and proprietary drivers.I promise you.Be sure you are using the newest version
vamsi360 is offline
Old 10-07-2008, 01:53 PM   #28 (permalink)
Pat
Pat's Avatar
^^ Dude whats with the fonts and colors ? Can you please use the default text formatting ?
Pat is offline
Old 10-07-2008, 01:57 PM   #29 (permalink)
Dark Star's Avatar
PCLinuxOS and Mandriva one come with almost ever codecs and proprietary drivers.I promise you.
No it does not.. they do provide Flash and mp3 and few more codecs.. But restricted codecs like real media, win32 and libdvd codecs need to be installed !
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 10-07-2008, 09:32 PM   #30 (permalink)
Easier in gentoo.
Thank you for enlightening me.
http://www.bash.org/?258908
mehulved is offline
