Old 04-06-2006, 01:21 PM   #1 (permalink)
Question Linux for Intel 433 Mhz machine
I need a lite linux distribution for my friend. He has a Intel 433mhz machine with 256 MB RAM and a 40 GB HDD. The chipset is Sis and audio is from ESS 1969 onboard. The distribution should mount windows automatically, play mp3 video cds, supports NTFS partition access in Windows. These are necessary things as he is new to Linux. Also the installation should be user friendly.
vinayasurya is offline
Old 04-06-2006, 01:51 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
Default Re: Linux for Intel 433 Mhz machine
any linux distro should do... provided u dont use gde or gnome desktop environment bcos they r heavy on sys usage..
there are other desktop environments also.. xfce etc.
Registered Linux user number 400618
champ_rock is offline
Old 04-06-2006, 01:53 PM   #3 (permalink)
I also want to know whether kubutu or ubutu plays mp3s and supports NTFS bulitin.
Old 04-06-2006, 03:34 PM   #4 (permalink)
String Phreak
mediator's Avatar
Damn small linux,puppy linux,kubuntu shud do!
mediator is offline
Old 04-06-2006, 03:48 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
ya they support both the things
Old 04-06-2006, 05:35 PM   #6 (permalink)
vignesh's Avatar
Not out of the box... It has to be added..
I recommend Vector Linux SOHO.... Its the fastest on low end machines
vignesh is offline
Old 04-06-2006, 07:11 PM   #7 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Linux for Intel 433 Mhz machine
I'll suggest for STX linux..
http://stibs.cc/stx/
praka123 is offline
Old 05-06-2006, 03:04 AM   #8 (permalink)
18 Till I Die............
You can try Vector Linux. It is based on slackware. It comes with IceWM, FluxBox and XFCE4. It is well optimised for old hardware.
It has some good tools like VASM, Gslapt. But, you cannot run GSlapt without root permission and there's no indication of that. Same applies to USB drives.
You can get more from www.vectorlinux.com
System requirements http://distro.ibiblio.org/pub/linux/...ion_table.html
mehulved is offline
Old 05-06-2006, 10:27 AM   #9 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Go for puppy linux without hesitation. The killer feature being it doesn't need to be installed, all settings are saved automatically. size: 60mb
chesss is offline
Old 05-06-2006, 04:35 PM   #10 (permalink)
vignesh's Avatar
Ya... You can install more software... I love puppy for that feature..
vignesh is offline
Old 05-06-2006, 05:27 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
are you kidding? GDE is the one of the lightest I use, KDE is the heavy one...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-06-2006, 08:18 PM   #12 (permalink)
Nope GNOME is heavy too. It takes much system resources. You won't feel it with the high end computer you possess but if you use the type of computer he is using you will know the difference. Or for that matter even kato found a big difference in GNOME and xfce on his P3 and I think 256MB RAM. Now, think this person using a even slower computer with lesser RAM.
mehulved is offline
Old 06-06-2006, 12:17 PM   #13 (permalink)
vignesh's Avatar
Gnome is also heavy made The light ones are
EDE,WindowMaker,Fluxbox.afterstep
twm and sawfish are really minimal
vignesh is offline
Old 06-06-2006, 02:39 PM   #14 (permalink)
saurabh.sauron's Avatar
i agree with qwerty. GDE is quite light. it only depends on swap. GDE doesnt tax resources.
saurabh.sauron is offline
