| Forum |
#1 (permalink) |
My modem is D-Link Data/Fax/...... Modem and my internet connection is of BSNL. Anybody please tell me how to connect to internet through Fedora.... P.S GNURag.. Can i get your permission to republish this in the General section if I get no positive answers???
http://geeksbay.monzilla.info - My Tech Blog |
#2 (permalink) | |
FooBar Guy
You can try configuring # kppp and select /dev/modem as the modem device... If it is an internal modem, then you have to download drivers for your modem chipset. Search Q & A section, there are many threads which have been replied in the past...
- -- http://www.MovieAB.com - A tiny movie mashup! |
#4 (permalink) |
The FIRST step towards finding a Linux driver is identifying the modem's CHIPSET!
How to find CHIPSET under linux? Use cat /proc/pci or lspci Next fire google.co.in/linux and search for linux CHIPSET modem driver; download; compilel; install and use the kppp or other .program to configur ISP account. For more visit www.linmodems.org
Who am I? What am I doing? Why this happened to me? Are you stuck in life? Then read the most age old “Bhagwat gita” to solve all mysteries of life. |
#5 (permalink) |
FooBar Guy
Ah this is what i had posted in Q & A section sometime back... sometime try searching this forum also...
http://www.thinkdigit.com/forum/view...internal+modem ----------------------- Internal Modems are not really true modems, in the sense that they use software instruction set to work... whereas external modems have firmware installed onto the chipset itslelf... Much more information or driver kits for particular chipsets can be obtained at: -> Taken From: linmodems.org * http://www.heby.de/ltmodem Lucent/Agere modem resources Manufacturer names of Lucent or Xircom may be displayed by the query "lspci -vv". These may be supported. The Lucent AMR modems are definitely not supported. * http://developer.intel.com/design/mo...rt/drivers.htm Intel HaM driver * http://www-124.ibm.com/acpmodem/ IBM's Mwave modem driver for Thinkpad 600E and newer laptops. This is new modem card format, neither ISA or PCI. * http://linmodems.technion.ac.il/pctel-linux/ Jan's PCTel Resources * http://www.linuxant.com/drivers/ Linuxant offers the latest and greatest general purpose Conexant drivers for Linux. * http://walbran.org/sean/linux/stodolsk/linux111.zip Driver for ESS ISA Modems. Only for earlier 2.2 kernel versions. * For 3COM/US Robotics Inc. winmodems, drivers were NOT available as of May, 2001. For more information visit : www.linmodems.org You can also download and install the soft modem driver form the motorola website < http://www.motorola.com/softmodem/driver.htm >
#6 (permalink) |
you can also refer to this thread for setting up D-Link modem:
http://www.thinkdigit.com/forum/viewtopic.php?t=7084
You are a living magnet. What you attract into your life is in harmony with your dominant thoughts. |
#7 (permalink) | |
I still can't configure my modem. I dectected my system settings are : Quote:
Please somebody help me to get a free driver for HCF Rockwell Modem.
#8 (permalink) |
sorry there is no free driver available i too had the same problem and as a final step i bought an external modem. The external modem (serial port type) do not require any drivers and are auto detected and work at full speed so i suggest buy an external modem say dlink and enjoy.
**** happens |
#11 (permalink) |
Hey sujith I used the linuxant d rivers a while back ... despite the 14.4 kbps limit I got speeds of 2-3 KBps ... worth a try ...
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e |
#12 (permalink) |
FooBar Guy
hmmmm.... there's nothing you can do it seems.... you can get drivers from your friends or otherwise try out the 14kbps driver... TurboLinux 9 that comes bundled with Compaq PCs have internal modem RPMs included... i dunno for which chipsets it is meant for.... i have a look at it again
Better than the best option, get yourself an external modem....
| Bookmarks |
| Thread Tools | |
| Display Modes | |
