Old 23-05-2006, 09:58 AM   #1 (permalink)
Default RH9 - XServer failed - help
Hi,
I prayed to God thousand times b4 installing RH9 that xserver prob shud not rise. but it happened. After installing, RH9, and reboot..everything worked properly then the next day when I entered, it says XServer cannot be started
and two modules namly bitmap, pcidata are not found. So, the OS will stay in text mode.
The modules are in /usr/X11R6/lib i think so.. when i tried opening that directory it says I/O error. Same problem is faced by many of them I think so (found when googled) but none of them have told the solution
Plsease help me. I googled for the same problem and found nothing useful.
thank u very much.
elumalai is offline
Old 06-06-2006, 10:17 AM   #2 (permalink)
Default Re: RH9 - XServer failed - help
ok..i somehow found it myself...
just reinstall the xserver -- this is what i found in a forum.
typed in the command prompt rpm -ivf -force xi386.rpm(something like) filename forgot.
That;s it. Now my Pc boots in GUI mode too.
upto this it is good.
but a new problem, whatever I type like 'root' or my login account name. It says incorrect username or caps lock. guys pls help on this probs. i googled exhaustively and found fruitless.
Pls Pls help me.
elumalai is offline
