Old 20-05-2006, 06:58 PM   #1 (permalink)
Default Linux Booting Problem
I have recently installed Suse 9.1 from an old Digit DVD.It was working fine but after that I installed Windows XP Pro.Since then Linux is not booting.How can i install the boot loader again.
vineetrocks2005 is offline
Old 20-05-2006, 07:17 PM   #2 (permalink)
ionicsachin's Avatar
Default Re: Linux Booting Problem
You will have to install Linux again. But while installing choose only upgrading and just set the boot loader. It' ll not effect ur previous settings. Otherwise I dont think there is any other way because while you install Windows a command "format /mbr" is executed which cleans the master boot record and i suppose it is unrecoverable.
ionicsachin is offline
Old 20-05-2006, 07:54 PM   #3 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Linux Booting Problem
No need to reinstall linux,if u r sure that u didnt install M$ Windows over previous Linux install...U can use any rescue cd to fix the GRUB-boot loader for linux...
http://www.linux.com/article.pl?sid=04/11/18/232240
praka123 is offline
