Old 19-05-2006, 11:16 PM   #1 (permalink)
Default permissions probs... pls help
hi,
i dont know what i did... but now its like this and i am not able to change the permissions or delete it.. how do i do it... pls help...
drwxr-xr-x  2 nfsnobody nfsnobody    1024 May 19 18:59 a
drwxr-xr-x  2 nfsnobody nfsnobody    1024 May 19 18:59 Alaipayuthey
drwxr-xr-x  2 nfsnobody nfsnobody    1024 May 19 18:59 7G Rainbow Colony
drwxr-xr-x  2 nfsnobody nfsnobody    1024 May 19 18:58 manmadhan
/legolas
legolas is offline
Old 20-05-2006, 01:07 AM   #2 (permalink)
Default Re: permissions probs... pls help
Login as root and do
cd /whatever/dir
chown USERNAME:USERNAME *
where USERNAME is your normal username ..
Should work. Strange why this problem occured :S
rohandhruva is offline
Old 20-05-2006, 01:58 PM   #3 (permalink)
vignesh's Avatar
I think you should do that as root... Since you can`t login as nfsnobody... Use the root account and as he said change the USERNAME to your name not root...
vignesh is offline
Old 20-05-2006, 03:40 PM   #4 (permalink)
Hmm.. wasnt that exactly what I said ?
Old 21-05-2006, 09:27 AM   #5 (permalink)
vignesh's Avatar
Fine... I didn`t read your post I just posted my reply...
vignesh is offline
Old 21-05-2006, 11:12 PM   #6 (permalink)
nope!!! it dint work out!
/legolas
legolas is offline
Old 22-05-2006, 03:50 PM   #7 (permalink)
vignesh's Avatar
Do you get any error Pls post it here Also post the command you entered...
vignesh is offline
Old 22-05-2006, 07:21 PM   #8 (permalink)
18 Till I Die............
See if this can throw some light http://www.redhat.com/archives/taroo.../msg00353.html
mehulved is offline
Old 23-05-2006, 08:41 PM   #9 (permalink)
it says.... nothing can be done except for recompiling the KERNEL for such a small thing???
/legolas
legolas is offline
Old 23-05-2006, 09:52 PM   #10 (permalink)
recompiling the kernel isn't such a big thing and in fact it is really good. You can have a look at gentoo docs on how to compile a kernel. Gives you a good idea. I once saw slackware kernel and realised how bloated these kernels are. Dunno about RH ones. But, it will be good to have your own kernel. I am sure you will find good tuts on that on the net.
mehulved is offline
