Old 08-05-2006, 01:29 PM   #1 (permalink)
Default problem with ubuntu
i had install ubuntu 4x version
it was working normaly with my crt 17 " lcd
monitor
but now i have lcd monitor sony 17 inch hs75
whenever i boot with ubuntu after bootup process
it give error out of range ,the starting window does not
come up on the screen
even though i could hear backgound stating sound
is this problem with my lcd or what
because window works fine
or i have to install new version of ubuntu Or linux
shivi4 is offline
Old 08-05-2006, 05:18 PM   #2 (permalink)
18 Till I Die............
Default Re: problem with ubuntu
Restart your computer. When grub shows up, go to the ubuntu entry. Instead of pressing enter here, press 'e'.
Now scroll down to the entry where something like following is given
kernel   vmlinuz-2.4.xx ro
The above is just an example it may vary in your case.
Now press 'e' again and add 'lowres' at the end.
Now press esc and then b.
This should help but it is only a temporary solution. I will have to search for a permanant one. Or wait for someone else to post it.
mehulved is offline
Old 08-05-2006, 08:52 PM   #3 (permalink)
vignesh's Avatar
Just log into one of the virtual consoles (f1 to f6) and type sudo xorgconfig and change the refresh rates of your monitor and then restart X
If you don`t know the refresh rates check your Manf website
vignesh is offline
Old 09-05-2006, 10:30 AM   #4 (permalink)
DO NOT RUN sudo xorgconfig. It is not "The Debian Way". Do
on ubuntu 5.x
sudo dpkg-reconfigure xserver-xorg
on ubuntu 4.x
sudo dpkg-reconfigure xserver-xfree86
Also, xorgconfig wont work on 5.x since that program is not there ! And it is a CLI program, which is confusing for new users.
rohandhruva is offline
Old 09-05-2006, 11:13 AM   #5 (permalink)
The Linux Man !
paragkalra's Avatar
Arrow Re: problem with ubuntu
Just check the Bios setting of your Video RAM. It must be 8 MB or more with 256 colours,
Parag.A.Kalra, The Linux Man
http://www.paragkalra.com/
In this world without WALLS and GATES who need WINDOWS! USE LINUX! STOP PIRACY! GO OPEN SOURCE!
paragkalra is offline
