Old 27-04-2006, 08:42 PM   #1 (permalink)
Unhappy Problem with Gnoppix Live CD.
I just aquired a Linux Live CD iso from a friend and copied it to my harddrive. It has the file name Gnome LiveCD_2.12_i386_en_5 . On opening it up with WinRAR I found out it was Ubuntu. I soon found out that it is Gnoppix version 2.12 .I used Nero to burn it as an image on a cd rom and booted via it. My Cd-Rom is set to boot first but the CD won't boot. Could you please give me instructions on how to create a bootable cd from the above in Nero 6 or Power ISO. Otherwise - I had read an article once on Digit to run Live Cd's without burning them. How can I go about this?
I have Windows XP SP2 on NTFS with 2.66 GHZ processor, 512 MB DDR 400MHZ ram, 915 MSI motherboard using the onboard graphics plus an 80 GB hardrive and a DVD-Rewriter.
Please reply at the earliest.
Last edited by wweundertaker; 28-04-2006 at 12:45 PM. Reason: Just found somethings out.
wweundertaker is offline
Old 29-04-2006, 04:40 PM   #2 (permalink)
18 Till I Die............
Default Re: Problem with Ubuntu Live CD.
Start nero. -> open nero images -> in the file type drop down box select *.iso -> navigate to where the iso is located -> now select it and open -> burn the image.
mehulved is offline
Old 29-04-2006, 09:05 PM   #3 (permalink)
vignesh's Avatar
Gnome 2.12 livecd is based on Hoary.... Open Nero -> cd& Backup->burn image to disc
vignesh is offline
Old 01-05-2006, 11:34 AM   #4 (permalink)
Smile Re: Problem with Ubuntu Live CD.
hello,
Thanks both of you, but I couldn't get the CD to boot by both ways. I then installed PowerISO and then created a bootable CD. It runs great and I am happy with Linux. Could you suggest me how to install some new programs or games since it has become boring seeing the same old interface. I am on a Live CD.
Thanks.
Old 01-05-2006, 11:40 AM   #5 (permalink)
Well sorry you can't install anything on ubuntu live cd. For that you can get puppy linux and burn a multisession cd. Or try games Knoppix. Or you can even install some linux distro on your hard disk.
mehulved is offline
Old 01-05-2006, 01:12 PM   #6 (permalink)
vignesh's Avatar
Yes you can... But it won`t be persistent. (i.e) You have to do it everytime you boot. ..For example you can download beep-media-player from the ubuntu repository..I recommend download than using apt.
Then open a terminal and
sudo dpkg -i *.deb to install,replace * with the file name or this itself will work just fine....
I used to do this long time back when I used Ubuntu livecds...
vignesh is offline
Old 01-05-2006, 01:20 PM   #7 (permalink)
Raiden Bee's Avatar
Anyway a live cd will load onto RAM or go directly from your CD- Drive....you cant install software directly to these
"Nobody's perfect and I stand accused................
....I'm at a loss of words and that's my best excuse"
Heck! no BBcodes in sig! Waa!
The Bee Blogs Here:
http://pooryoungggeek.blogspot.com
Raiden Bee is offline
