26-04-2006, 05:56 PM
Fedora Core 5 CD mounting problem
I am using FC5. I have problems mounting CDs. VCDs don't mount at all. Other data CDs automount, but when i double click the Cd icon, I get a 'permission denied' error. Whats going on here?. Help needed.
WE ARE THE BORG
YOU WILL BE ASSIMILATED
RESISTANCE IS FUTILE
28-04-2006, 01:36 AM
String Phreak
Re: Fedora Core 5 CD mounting problem
are u mounting them as root.............................................. .................?
28-04-2006, 04:07 AM
Learner
post ur fstab.....
and can u acess them as root
28-04-2006, 08:59 PM
The following are the contents of my fstab
/dev/VolGroup00/LogVol00 / ext3 defaults 1 1
LABEL=/boot /boot ext3 defaults 1 2
devpts /dev/pts devpts gid=5,mode=620 0 0
tmpfs /dev/shm tmpfs defaults 0 0
proc /proc proc defaults 0 0
sysfs /sys sysfs defaults 0 0
/dev/hdc7 /mnt/fdrive vfat defaults 0 0
/dev/hda /media/dvdrom auto defaults 0 0
/dev/hdb /media/cdrw auto defaults 0 0
/dev/VolGroup00/LogVol01 swap swap defaults 0 0
I don't know why cds don't open even though they are detected. Linux installation disks mount normaly though.
WE ARE THE BORG
29-04-2006, 09:17 PM
Are you trying to mount the cd/dvd after its automounted ? Then that error is possible... Or remove the auto in fstab and trying mounting them from the terminal and see it this works ?
30-04-2006, 11:35 AM
There is no need to manually mount in FC5. Disks mount automatically as you insert them. The problem here is whenever I insert a disk, say a VCD, nothing happens. It isn't even detected. But other disks get detected & the menu asking me what to do appears. When I tell it to open it in new window, a new window appears & I get an error 'permission denied'. The same in the user as well as the root account.
WE ARE THE BORG
01-05-2006, 08:23 AM
BE FREE
probably vedio format is not supported by the default player,download the one supporting the format,its not hte new problem in fc, I have seen it in all previous version,please let ne know whether fc 5 is supporting mp3(I suppose not).
01-05-2006, 10:06 AM
hmmm... I don't think that is the problem. I have xine with all the codecs installed. Even without the codecs, the Cd should atleast open & show me the files, right?.
And no FC5 doesn't includd MP3 codecs.
WE ARE THE BORG
01-05-2006, 10:50 AM
Learner
umounting and mounting does not work...
what does it show when u ls the directory
01-05-2006, 06:56 PM
VCD's cannot be mounted and viewed as a directory, like data CD's. They have a different file format, and the correct way to access them is to open your media player, and ask it to play the cd. Windows does try to access a VCD like a normal data cd, but if you want such behaviour under linux, you need to set up cdfs and mount the disc using the "-t cdfs" option.
The permission denied error is strange, could you post the output of "ls -l /media" when you insert a cd?
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
07-05-2006, 08:57 AM
Man I don't get anything when I cd into the CD directory -/media/hda . Its as if the CD isn't there. This is a really a wierd problem.
WE ARE THE BORG
22-06-2006, 04:19 PM
Can anyone help with this problem?. I have still not been able to solve it. I have googled enough. Any clues, ideas, anything at all will help.
I will recap evrything once more-
1. I insert CD (any CD)
2. CD gets detected & I get the prompt asking me what to do
3. I click on 'open in new window'
4. A new window opens & I get a 'permission denied' error
The same thing whether I am logged in as root or as normal user.
When I use terminal & CD into /media/cdrw (my drive) & ls, I get nothing. Its as if the CD isn't there.
The o/p of ls -l /media is
drwxr-xr-x 2 root root 4096 Apr 4 19:33 cdrw
drwxr-xr-x 2 root root 4096 Apr 4 19:33 dvdrom
WE ARE THE BORG
22-06-2006, 04:29 PM
18 Till I Die............
Try typing this command after you insert the video cd.
su
mount -t cdfs /dev/hda /media/dvdrom
See if it helps.
22-06-2006, 04:36 PM
I happenned to try exactly that & it seems to be working. The CD mounted & I was able to access the files!. I tried it with a data CD though. ANyways, now its clear that the problem is with the automounting mechanism. How do I proceed to set it right?.
WE ARE THE BORG
22-06-2006, 04:41 PM
Edit the line in ur fstab as follows
/dev/hda /media/dvdrom iso9660,udf,cdfs defaults 0 0
/dev/hdb /media/cdrw iso9660,cdfs defaults 0 0
Now try to mount with following command
su
mount /media/dvdrom
22-06-2006, 04:48 PM
hmmm... the above command simply specifies each possible filesystem, instead of using 'auto' , am I right?. What good will that do?. I mean, the problem seems to be with the KDE automounting system.
I tried what have mentioned. It doesn't make any difference. Automounting still doesn't work.
WE ARE THE BORG
22-06-2006, 05:01 PM
If you haven't changed the fstab entries yet, do this.
Give command
su
mount /media/dvdrom
If you get error then type
It will give a clue on the error. I don't know why but specifying the filesystem explicitly works rather than giving auto.
I don't think it is a problem with KDE automounter. Make a change in fstab and then see what happens.
23-06-2006, 11:05 AM
I made the necessary changes in the fstab, but it makes no difference. Its the same. I still have to maually mount CDs
WE ARE THE BORG
23-06-2006, 11:24 AM
#19 (permalink)
Whichever VCD/DVD playing software you are using say VLC Media Player, give the
path to your DVD drive (in expert mode options). And make it the default player for
playing VCD & DVD. I did this in Ubuntu & it mounts VCD/DVD automatically!!
The default action is that it doesn't know what to do with the media loaded.
23-06-2006, 01:56 PM
#20 (permalink)
And have you restarted your computer after that? I don't know the reason why but in my case it happened. I was struggling with the automounting problem even after changing the entries in fstab. But, after a reboot everything was mounting properly.
23-06-2006, 02:09 PM
#21 (permalink)
Commander in Chief
Yes you have to restart for fstab settings to take effect, cause it gets loaded at startup alone.
Harsh J
www.harshj.com
23-06-2006, 02:16 PM
#22 (permalink)
I tried restarting also. No use. Same problem.
WE ARE THE BORG
