Old 11-04-2006, 07:33 AM   #1 (permalink)
BE FREE
Default is it possible?
Is it possible to retrieve free space from a hdd installed with linux, it is like this I installed rhel4 on the machine and dedicatd complete 20gb hdd for it now I know more than 13gb is free ,what i want is to slice out 5-6 gb of it to install other OS,are there any commands,is resize of any use,please let me know.
azaad_shri75 is offline
Old 11-04-2006, 12:29 PM   #2 (permalink)
desertwind's Avatar
Yes, parted can do that. But I warn you, if you are a n00b or not, resizing / partition is not recommended. And furthermore you need to unmount the partition you need to resize, so better use a livecd like ubuntu for doing that.
The command is as follows
parted -i /dev/hda resize hda1 0 10240
This will resize /dev/hda1 to 10 GB starting from 0 MB.
Better use a frontend for parted like gparted or QTparted.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 12-04-2006, 08:14 AM   #3 (permalink)
BE FREE
thanks man.
Old 14-04-2006, 08:24 AM   #4 (permalink)
left this forum longback
praka123's Avatar
again u can use gparted GUI for the same.
praka123 is offline
