Old 09-04-2006, 08:58 AM   #1 (permalink)
nach p's Avatar
Default FC5 GUI Problem
I installed FC 5 yesterday.After installation of packages when system reboots it enters into 3rd level .I configured my driver as "vesa" becoz default driver shows out of range.
I have given "init 5".
it entered into GUI mode ,I logged in as root but whole screen appeeared as blank.And it displayed only: MY computer,trash and blank taskbar.When i right clicked in the screen it displayed Application"Gnome background utility" closed down ..... Restarting application
doesnt help.
Need u r help urgently!!
nach p is offline
Old 09-04-2006, 03:58 PM   #2 (permalink)
Try adding in KDE and working that out. I hope it helps you.
I do know everything, just not all at once. It\'s a virtual memory problem.
Elitecoder is offline
Old 09-04-2006, 04:50 PM   #3 (permalink)
Default Re: FC5 GUI Problem
which was the default driver?
if you get out of range set the
HorizSync
VertRefresh
values correctly as per your moniter spec...
in the /etc/X11/xorg.conf file...
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 10-04-2006, 09:22 PM   #4 (permalink)
nach p's Avatar
Reinstalled FC5 with KDE.
It entered into runtime level 3.
#system-config-display --set-vsync=50-160
#system-config-display --set-hsync=30-70
then init 5 and it worked.
@ Naveenchandran I opened /etc/X11/xorg.conf file with vi editor but it is blank.
Now I have 2 questions
*How can I switch to Gnome without reinstalling FC &
*How can I enter into GUI mode directly.
Thanks guys gor Help
nach p is offline
Old 10-04-2006, 09:32 PM   #5 (permalink)
desertwind's Avatar
1. you can use switchdesk-gnome or you can select DE at the time of login.
2. edit your /etc/inittab file. you'll see a line like
change 3 to 5.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 11-04-2006, 10:10 PM   #6 (permalink)
nach p's Avatar
@Desertwind
I changed default run time level to 5 and its working perfectly.
But still Gnome prob. is not solved.I have not installed Gnome at the time of installation so at the time of log in I cant choose Gnome.I tried to upgrade installation to install Gnome but after boot loader installation,it skipped choosing packages stage and installation finished.
Can i install it directly from FC5 DVD ?
One more prob. ,When I clicked on storage media it showed Permision Denied.I loged in as a root user!!!!!
Thanks for reply
nach p is offline
Old 12-04-2006, 04:25 AM   #7 (permalink)
El mooooo
eddie's Avatar
I think FC 5 comes with a Package Manager named Pirut or something like that. It should be there under "main menu --> system --> package manager" or some where around there. If you can't find it, just launch it from a konsole window by typing pirut. From this package manager, you should be able to install GNOME from your DVD.
Post the contents of /etc/mtab and tell us the drive you are trying to access.
eddie is offline
Old 18-04-2006, 11:27 AM   #8 (permalink)
baccilus's Avatar
For installing Gnome:
Click on 'f' on lower left hand side of desktop. Go to 'system' then 'Add/Remove program'. You will understand the rest yourself.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline
