Old 07-04-2006, 02:48 AM   #1 (permalink)
Default WLAN configuration ?? How to
Has anyone configured WLAN on linux.... i am facing a serious problem configuring my WLAN... i tried using ndiswrapper... but no luck.....
ndiswrapper -l says invalid driver....
FYI.....
i have a broadcom 4318 card...
distribution : fedora 4...
latest version of ndiswrapper
vinuzz is offline
Old 07-04-2006, 12:04 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
I got my WLAN up with no difficulty. From the network-admin applet, i selected DHCP and everything works out of the box!
http://web.gnuer.org
GNUrag is offline
Old 08-04-2006, 05:47 PM   #3 (permalink)
Had my share of problems configuring Atheros WLAN in Redhat/Fedora.But it works like a charm in Ubuntu Breezy.
Infact in my case its making use of mad wifi project.I also have a Wireless PCMCIA card using a Broadcom chipset which too doesnt work in Fedora/Redhat except for NDISwrapper solution.
What problems are you facing in NDISwrapper?
www.Oobertech.net
digen is offline
Old 12-04-2006, 12:13 AM   #4 (permalink)
you need to use WinXP drivers. Not even 2k/2k3 drivers will do.
daj123 is offline
Old 12-04-2006, 02:44 AM   #5 (permalink)
El mooooo
eddie's Avatar
Look at this wiki entry
http://ndiswrapper.sourceforge.net/m...dex.php/Fedora
It has complete instructions for FC4 with Links to BCM 4318 drivers. Though those driver are from Acer, they might work for you as well. Try it.
eddie is offline
