Mandriva Linux 2006 is the best choice for you since you a newbie to Linux.
Mandriva Linux 2006 Overview:
http://www.mandriva.com/en/individua...s/2006overview
* 'Mandriva Discovery' is for users switching to Linux
* 'Mandriva PowerPack' is for advanced power users.
* 'Mandriva PowerPack+' is for Small Office/Home Office users
Where can I get it ?
You can download a free version from their website :
http://www.mandriva.com/en/downloads/free (Choose Mandriva Linux 2006 ISO for x86-64 (since your Processor is 64-bit)
There is also a commerical version of the product available. It comes bundled
with proprietary software which are not available in the Free version!!
Do I need to create a partition ?
Yes, ofcourse. You need to create a separate partition of 12 GB.
Out of that 12 GB , give 10.5 to Root ("/") and 1.5 GB for Swap (ie., Virtual Memory)
Technical things to know about my PC?
Don't worry, the Mandriva Linux installer will detect all the devices. Just select 'OK'
in case something goes wrong, you can change the Settings using the 'Mandriva Control Center'
