Old 12-03-2006, 01:42 AM   #1 (permalink)
Default yum update error.... :( pls help me!
i tried to install yum, and also configured proxy, but when i try to run it, i get this error. pls help me with this. ihave tried to the fullest possible.
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   /usr/lib/python2.4/site-packages/libxml2mod.so: undefined symbol: xmlDictCleanup
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.1 (#1, May 16 2005, 15:19:29)
[GCC 4.0.0 20050512 (Red Hat 4.0.0-5)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
/legolas
legolas is offline
Old 12-03-2006, 01:53 AM   #2 (permalink)
desertwind's Avatar
try installing the package libxml2-python24
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 14-03-2006, 02:02 PM   #3 (permalink)
vignesh's Avatar
@desertwind Never used yum is it similar to apt ?
vignesh is offline
Old 14-03-2006, 06:41 PM   #4 (permalink)
Satissh S's Avatar
Yes.. yum is written in python and is for rpm what apt is for deb.. though not quite as traditional.. You can use apt with rpm though.. This is what suse users have been doin for years..
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 14-03-2006, 08:56 PM   #5 (permalink)
left this forum longback
praka123's Avatar
apt4rpm exists and U can d/l for RH or Fedora from dags.wieers.com or atrpms.net or any..u can also try synaptic in fedora from these sites..
praka123 is offline
Old 14-03-2006, 09:15 PM   #6 (permalink)
desertwind's Avatar
SmartPM has got a better gui and preconfigured repositories.
Old 14-03-2006, 09:28 PM   #7 (permalink)
vignesh's Avatar
Thanks guys..I prefer Debian and its derivates always..
vignesh is offline
Old 15-03-2006, 07:38 PM   #8 (permalink)
i am not able to configure stil after installing libxml2-pyth* .... any1 have encountered this prbs before???
/legolas
legolas is offline
Old 15-03-2006, 07:58 PM   #9 (permalink)
desertwind's Avatar
are you sure that the file is libxml2-python24* ? libxml2-python26 wont work in your case.
Old 16-03-2006, 12:36 AM   #10 (permalink)
El mooooo
eddie's Avatar
execute the following commands and post the output
rpm -q python
rpm -q libxml2-python
Also where did you get the RPM of Yum from? Did you make sure that they are for Fedora and not for mandrake or some other rpm based distro?
eddie is offline
Old 17-03-2006, 09:11 PM   #11 (permalink)
hi,
here is the output. and i downloaded from the yum home page for FC4...
bash-3.00$ rpm -q python
python-2.4.1-2
bash-3.00$ rpm -q libxml2-python
libxml2-python-2.6.19-1
libxml2-python-2.4.19-4
bash-3.00$
/legolas
legolas is offline
Old 17-03-2006, 10:49 PM   #12 (permalink)
desertwind's Avatar
i think ur problem is conflict between 2 versions of libxml2-python. try uninstalling 2.6, if not having any dependancy problems.
Old 19-03-2006, 12:30 AM   #13 (permalink)
El mooooo
eddie's Avatar
Yes the problem is the conflict between 2 versions but the version to uninstall is 2.4 and not 2.6. 2.6 series is the latest version of libxml2 bindings and looking at the installed python version that is what he needs. iirc 2.4 version was used by RedHat while he seems to be using Fedora.
eddie is offline
Old 20-03-2006, 09:02 PM   #14 (permalink)
uninstalled 2.6 also .no use.. i am not trying it once more!
/legolas
legolas is offline
