Let me give you some answers... Of course, the ones given above are also well qualified...
Originally Posted by hameed
Hi,
I have two operating system in my computer one is window xp sp-2 and other is Ubuntu.
Please anybody can tell me how can i see the hard disk in Ubuntu
I mean i want to see the hard disk icon in my computer like window xp
To do this,
right click on the desktop, then
point to shortcuts, click on Drive (or something like that) and choose from one of your windows drives which may be found in /media/hda
X where X is 1,2,3...
how can i install yahoo messenger and msn messenger and other applciations
To do this, either install GAIM from Adept Package Manager, or if u want the exact Yahoo Messenger and MSN Messenger,
Then, try
Yahoo Messenger for Linux/Unix - It really sucks though... And Follow instructions on that page according to Debian...
Alavaro's MSN Messenger - The link is the downloads page. Choose ubuntu from the 32-bit or 64-bit column according to your PC... (if in doubt go for 32-bit) and download the package onto your /home/<username> folder. Then go to terminal (command prompt) and then type
sudo dpkg -i <packagename>.deb
and how can i make icon on desktop
Same as drive icon, right click on desktop, point to create shortcut, in that, Click "Application" and a page comes which allows you to select the software according to classification such as Internet, etc.
and how can i use USB flash devices.
Ubuntu has a plug-n-play enabled, so just plug in the USB device and it will get detected...
Please I have lot of question about Ubuntu I am new in Ubuntu so please help me if somebody knows please dont give me a link for Ubuntu unofficial starter guide it will not help me.
Please anybody knows Ubuntu very well, kindly help me.
thanks,
We are all here to help, and that is why it is called a "Community"
Also, you CAN use a guide sometimes, as it has many important points like how to install from deb, rpm, tar, etc. explained well... so better refer it as well...
Unofficial Ubuntu Guide
Prav.
