Old 28-02-2006, 07:08 PM   #1 (permalink)
Default problem with system date in FC4
hi guys,
I use FC4 and while installing, i forgot to set the date.... by mistake, it has been set to 2007!!! and i hav been working on it for arnd a week... after that i noticed the date problem and reverted back to the original date. now that, this is done, when i try to install some software with the commands say,
./configure
make
make install
i get this error....
Originally Posted by legolas
make[3]: Entering directory `/home/arun/libsbml-2.3.4/src/bindings'
make[3]: Warning: File `/dev/null' has modification time 3.2e+07 s in the future
make[3]: Nothing to be done for `include'.
make[3]: warning: Clock skew detected. Your build may be incomplete.
pls help me with this... its really important... should i change the dates of the already installed directories(which have dates 2007) ??? if so how to? any alternatives?
/legolas
legolas is offline
Old 28-02-2006, 09:26 PM   #2 (permalink)
First, you should try restarting once and trying to compile the program again, as restarting will recreate all files in /dev ...
Else, you can change dates of files in your system using the "touch" command. Running 'touch *' in a directory will set all files in the current directory to have the current system date as their modificaction date.
As you need to change the dates of all files in the system, you will need a simple loop to do it, something like running
for i in `find` ; do touch $i ; done
In the / directory.
But be careful, running this changes all dates and may have a bad affect on some applications/processes. Also you should unmount all drives before running this.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 01-03-2006, 02:26 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
Ujjwal, why go into a for loop when find itself can execute commands upon its output?
 $ find . -exec touch {} \;
http://web.gnuer.org
GNUrag is offline
Old 01-03-2006, 02:43 PM   #4 (permalink)
I wasn't aware of that, thanks for the info
ujjwal is offline
Old 02-03-2006, 11:25 AM   #5 (permalink)
i restarted and recompiled... but stil it says... WARNING: <filename> is upated 1.1e 03 seconds in future... or something... and at the end it says
warning: clock skew detected: your build may be incomplete
can i use that command u gave to reset the dates? wil that be of any real harm? y should i unmount the drives?
/legolas
legolas is offline
Old 02-03-2006, 01:12 PM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Note: True programmers never worry about WARNINGS ... Then only worry if its an ERROR
GCC/Makefile uses source file's timestamp to determine which files need to be recompiled, and which have been edited. I guess Ujjwal's trick might just work!
GNUrag is offline
Old 02-03-2006, 02:59 PM   #7 (permalink)
I worry coz i dont get it compiled!!! and after trying many times. that makes me think there is some prob with this only. thks anyway.
/legolas
legolas is offline
