| Forum |
#1 (permalink) |
I ALREADY HAD A DUAL BOOT WITH C:/WIN98 AND D:/WINXP AFTER INSTALLING LINUX THE OPTIONS FOR BOTH WIN HAVEGONE AND I CANNOT LOG ON TO THEM THE BOOTLOADER WAS GRUB HELP
Education... has produced a vast population able to read but unable to distinguish what is worth reading |
#2 (permalink) |
boot into linux and create a boot floppy
TO RESCUE UR WIN PARTITIONS BOOT INTO UR SYSTEM USING UR WINXP CD AND TYPE : fixmbr this would allow u to boot into windowsxp and 98 if u want to boot to all 3 oses then rst ur pc and boot to linux using the linux boot floppy goto contrl center and change bootloader to lilo traverse to /etc/lilo.conf where u may change default boot options save and exit and type lilo and press enter this should solve ur problem if not .... Gnurag is on the way he WILL solve ur problems .. cheers harish
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION -------- PARKINSON\'S LAW |
#3 (permalink) |
On which drive is Win98 installed and on which one WinXP? I think it must be C and D respectively. But please clarify. You can edit grub.conf file and get those things back.
:: Free hosting and free domain names available in special cases. Conditions apply :: |
#4 (permalink) |
FooBar Guy
Please clarify... You say after installing PCQ Linux, the options for Windows have gone ? is this correct ?
Did you configure Boot loader while doing the PCQ Linux Setup? Otherwise, if Linux is booting then there's no need to worry... You can edit your grub.conf files....
- -- http://www.MovieAB.com - A tiny movie mashup! |
#6 (permalink) |
You can boot into linux in a single user mode from a bootable CD ( generally the first instalation CD) and check the /boot/grub/grub.conf
The booting options are there.
GNU/Linux Fanatics\' Group >> http://forum.linuxjunkies.org Free hosting for GNU/Linux User groups >> http://www.swatantranet.com |
#8 (permalink) |
hey bud,
just try this out .http://www.geocities.com/epark/linux...w2k-HOWTO.html
Satyajit Tambe |
#9 (permalink) |
Isnt that most of the Linux distroes automatically identify Win partitions and configure Boot Loader automatically.This leads to another doubt,has he deleted Win.
http://swatrant.blogspot.com/ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
