| Forum |
#1 (permalink) |
I've been working on an Linux From Scratch OS for sometime now. It has been optimised for P4 i686 Processors and i'am already very fond of it. It has all multimedia capabilities , player , browsers , Mailers etc., as well as a few development tools such as Eclipse, Netbeans, Anjuta, Mono and also several Runtime Environments and toolkits used for building your own software from source. I dedicate it to this Digit OpenSource Community for motivating and Guiding me. => Is it possible to create an Ncurses based installer, that installs the Os as well as configures several settings such as network, partitioning, Configures X, Installs software binaries and bootloader? => I wan't to make the distro efficient as well as easy for the new linux user. Also i would wan't to upload it to somewhere so that the user can D/L and use it. Thanks for all your co-operation and inputs.. // This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Call it Emacs, Love it or Leave it. |
#2 (permalink) |
I have never tried anything beyond a simple LFS system, so I am really just talking out of the hat
You could make all the software you compile into packages (maybe a simple tar.gz file), after this the installers job will simply be to install each package and run some other configuration. The installer could be just an interactive script, instead of an ncurses program, like this - echo 'IP Address: ' read $ipaddr cat "address=$ipaddr" > /etc/network.conf Good luck!
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e |
#3 (permalink) |
@Sathish
That was grt evn I am trying to build LFS But not finding time.. But what abt the partition editor? if u want to make an installer?
Million's Of Open Minds Can't Be Wrong! http://nc.xmgfree.com/weblog Everybody Wants to go to Heaven...But nobody wants to Die! |
#4 (permalink) |
Similarily, for every other config such as say, if i wan't to create an Xorg.conf file for the user, then lets say if i wan't the user to input his monitor's Vertical and Horizontal Refresh rates.
echo 'Enter Vertical Refresh Rate' read $vrate cat "VertRefresh=$vrate" > /etc/X11/xorg.conf But how many scripts can i write? There are a hell a lot of config files to edit. Also Hardware Auto Detection is also a big problem. Also how to configure the kernel for all the generic type of Hardwares? Wouldn't it become bulky? Do distro configure the kernel based on each users hardware?? Also how about using Webmin as a system administration tool? It's easy and it directly edits the configuration files.. Thanks for the encouragement and inputs!!
#5 (permalink) |
First up the installer iso must be capable of booting into a live linux system detecting hardware, so that it can start the installer to install linux to harddrive.
@Naveen: I wan't use cfdisk. It's easy enuf for the linux newbie to use. But i want to write a script that starts it automagically also issues commands such as mke2fs (-j), mkreiserfs , mkswap etc, detecting the users partitioning setup and modifies the generic /etc/fstab automatically.
#6 (permalink) |
yes..
I think these links will be of use when it come to HW Detection.. http://packages.debian.org/testing/admin/hotplug http://lists.debian.org/debian-devel.../msg02415.html
#7 (permalink) |
18 Till I Die............
Well satish I guess you are going too fast. You are trying to do too much with your distro at a single time on your own. Just work on things one by one experience will help you getting so much done in a jiffy. I guess sourceforge will be a good place to submit it once completed.
#8 (permalink) |
Wire muncher!
don't go too deep into kernel configuration. just provide a generic i386 (which will obviously work on all x86)...and a generic i686 kernel. let the user haf the option of installing one during installation. if they want specific configs let them configure and compile their own.
about the live linux installer, why don't u take a leaf out of any of the morphix books?
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#9 (permalink) | ||
El mooooo
Please don't think that I am trying to deter you from making your own distro but I would certainly want to quote a few things.
What you need to ask yourself is that do you have enough time to maintain a whole distro? You might find a link and then develop one, but will you be able to maintain it? Will you be able to give updated packages of all the software that a user of your distro needs (and that too in time)? Will you be able to be on top of all the security flaws that are found in the applications provided by your distro and then patch them in time? If you think that you can do all that, then you should go ahead. I don't have any idea about installers but you can look at the following links for building your own customised Linux Live CDs. http://www.governmentsecurity.org/fo...howtopic=14661 http://www.linux-live.org/ http://home.tiscali.nl/berenstraat/ http://damnsmalllinux.org/cgi-bin/fo...77;hl=remaster |
#10 (permalink) |
left this forum longback
if you can hack debian new installer or anaconda based Fedora One to integrate with UR distro.
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#11 (permalink) |
FooBar Guy
And is there any reason why you dont want to reuse Knoppix's autoconfiguratiuon script? Its the best installer thingie i know. These are two scripts residing on /etc/init.d/knoppix-autoconfig and /etc/init.d/knoppix-hd-autoconfig I'd managed to customise this script for use with Gnoware. Though Gnoware wasnt made from scratch.
Basically, what you do is run this autoconfig script from the Lilo on top of BusyBox. Then your shell script based installer copies all the file to the hard disk and reboots. And voila! you are in your newly installed OS.
- -- http://www.MovieAB.com - A tiny movie mashup! |
#13 (permalink) |
Thanks for all the inputs, i'am very fond of my own distro and will work on an installer to it to make it available for every1. But my semester practicals is underway, so i'll work on it after 11th of this month. Thank all for your valuable suggestions and Ideas.
Cheers!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
