Old 06-02-2006, 05:39 PM   #1 (permalink)
Default Linux Installation Issue
Hi All,
i am facing some issues while installing Fedora .. need some troubleshooting
system config ;
AMD 3000+ processor 939 socket
MSI RS-IL 480
Seagate HDD 160 GB
It is partitioned 140 Gb(Win XP) / 20 B
now my problem is that whenever i try to install the Fedora by
inserting the disk , after a couple of steps ..it says that HDD not found !!
if any more Logs are required do let me know
can anybody help
rgds
Som
soumendra is offline
Old 07-02-2006, 06:30 AM   #2 (permalink)
First provide 10 g.b. unpartioned and try it.If the problem continues reply....
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 07-02-2006, 08:17 AM   #3 (permalink)
left this forum longback
praka123's Avatar
which version of fedora are U using..get latest one if possible.have the installer detects your harddisk..if it detects try manual partition..
praka123 is offline
Old 07-02-2006, 11:53 AM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
You have a SATA hard disk, dont you?
You need to boot the CD using 2.6 kernel and perform the installation, it will install smooth.
http://www.MovieAB.com - A tiny movie mashup!
GNUrag is offline
