Old 05-02-2006, 11:27 PM   #1 (permalink)
18 Till I Die............
Default Problem configuring canon i255 printer
I atlast got hold of drivers for my printer, Canon xnu i255. I just configured and started it. But, when I send test page to the printer I get the following error message
A print error occurred. Error message received from system:
cupsdoprint -P 'CanonPrinter' -J 'KDE Print Test' -H 'localhost:631' -U 'root' -o ' multiple-document-handling=separate-documents-uncollated-copies orientation-requested=3' '/usr/share/apps/kdeprint/testprint.ps' : execution failed with message:
client-error-not-possible
Can anybody help me out here?
http://www.bash.org/?258908
mehulved is offline
Old 06-02-2006, 12:17 AM   #2 (permalink)
El mooooo
eddie's Avatar
Does this help?
http://www.cups.org/articles.php?L291+I0+TFAQ+P1+Q
eddie is offline
Old 06-02-2006, 12:55 AM   #3 (permalink)
Maybe I have given wrong URI. Is there anyway to check which port is the printer connected to?
mehulved is offline
Old 06-02-2006, 01:31 AM   #4 (permalink)
El mooooo
eddie's Avatar
If it is a USB printer then the command lsusb passed as root should show you the port the printer is connected to.
eddie is offline
Old 06-02-2006, 02:15 AM   #5 (permalink)
It is detected by Ubuntu on parallel port 1. So, I did configure it right in Knoppix too. Now, in Ubuntu even after proper setup, it is shown as ready, whenever I give print a test page command, nothing happens at all. There is no response from the printer.
mehulved is offline
Old 06-02-2006, 09:42 AM   #6 (permalink)
El mooooo
eddie's Avatar
Upload your /etc/cups/printers.conf and /etc/cups/cupsd.conf some place. Also is the module for parallel port loaded? Check with lsmod and see if a module named "parport" is loaded or not.
eddie is offline
Old 06-02-2006, 01:58 PM   #7 (permalink)
I did 'lsmod' and parport_pc is present.
# Printer configuration file for CUPS v1.1.23
# Written by cupsd on Monday 06 February 2006 02:17:55 AM IST
<DefaultPrinter i255-ver.2.3>
Info i255-ver.2.3
DeviceURI canon:/dev/lp0
State Idle
Accepting Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
</Printer>
######## Server Identity
# ServerName: the hostname of your server, as advertised to the world.
# By default CUPS will use the hostname of the system.
# To set the default server used by clients, see the client.conf file.
#ServerName myhost.domain.com
# ServerAdmin: the email address to send all complaints/problems to.
# By default CUPS will use "root@hostname".
#ServerAdmin root@your.domain.com
######## Server Options
# ConfigFilePerm: permissions of configuration files like
# /etc/cups/printer.conf.
ConfigFilePerm 0600
# AccessLog: the access log file; if this does not start with a leading /
# then it is assumed to be relative to ServerRoot. By default set to
# "/var/log/cups/access_log"
# You can also use the special name "syslog" to send the output to the
# syslog file or daemon.
#AccessLog /var/log/cups/access_log
# Classification: the classification level of the server. If set, this
# classification is displayed on all pages, and raw printing is disabled.
# The default is the empty string.
#Classification classified
#Classification confidential
#Classification secret
#Classification topsecret
#Classification unclassified
# ClassifyOverride: whether to allow users to override the classification
# on printouts. If enabled, users can limit banner pages to before or
# after the job, and can change the classification of a job, but cannot
# completely eliminate the classification or banners.
# The default is off.
#ClassifyOverride off
# DataDir: the root directory for the CUPS data files.
# By default "/usr/share/cups".
#DataDir /usr/share/cups
# DefaultCharset: the default character set to use. If not specified,
# defaults to "utf-8". Note that this can also be overridden in
# HTML documents...
DefaultCharset notused
# DefaultLanguage: the default language if not specified by the browser.
# If not specified, the current locale is used.
#DefaultLanguage en
# DocumentRoot: the root directory for HTTP documents that are served.
# By default "/usr/share/cups/doc-root".
#DocumentRoot /usr/share/cups/doc-root
# ErrorLog: the error log file; if this does not start with a leading /
# "/var/log/cups/error_log"
#ErrorLog /var/log/cups/error_log
# FileDevice: determines whether the scheduler will allow new printers
# to be added using device URIs of the form "file:/foo/bar". The default
# is not to allow file devices due to the potential security vulnerability
# and due to the fact that file devices do not support raw printing.
#FileDevice No
# FontPath: the path to locate all font files (currently only for pstoraster)
# By default "/usr/share/cups/fonts".
#FontPath /usr/share/cups/fonts
# LogLevel: controls the number of messages logged to the ErrorLog
# file and can be one of the following:
# debug2 Log everything.
# debug Log almost everything.
# info Log all requests and state changes.
# warn Log errors and warnings.
# error Log only errors.
# none Log nothing.
LogLevel info
# MaxLogSize: controls the maximum size of each log file before they are
# rotated. Defaults to 1048576 (1MB). Set to 0 to disable log rotating.
#MaxLogSize 0
# PageLog: the page log file; if this does not start with a leading /
# "/var/log/cups/page_log"
#PageLog /var/log/cups/page_log
# PreserveJobHistory: whether or not to preserve the job history after a
# job is completed, cancelled, or stopped. Default is Yes.
#PreserveJobHistory Yes
# PreserveJobFiles: whether or not to preserve the job files after a
# job is completed, cancelled, or stopped. Default is No.
#PreserveJobFiles No
# AutoPurgeJobs: automatically purge jobs when not needed for quotas.
# Default is No.
#AutoPurgeJobs No
# MaxCopies: maximum number of copies that a user can request. Default is
# 100.
#MaxCopies 100
# MaxJobs: maximum number of jobs to keep in memory (active and completed.)
# Default is 500; the value 0 is used for no limit.
#MaxJobs 500
# MaxJobsPerPrinter: maximum number of active jobs per printer. The default
# is 0 for no limit.
#MaxJobsPerPrinter 0
# MaxJobsPerUser: maximum number of active jobs per user. The default
#MaxJobsPerUser 0
# MaxPrinterHistory: controls the maximum number of history collections
# in the printer-state-history attribute. Set to 0 to disable history
# data.
#MaxPrinterHistory 10
# Printcap: the name of the printcap file. Default is /etc/printcap.
# Leave blank to disable printcap file generation.
Printcap /var/run/cups/printcap
# PrintcapFormat: the format of the printcap file, currently either
# BSD or Solaris. The default is "BSD".
#PrintcapFormat BSD
#PrintcapFormat Solaris
# PrintcapGUI: the name of the GUI options panel program to associate
# with print queues under IRIX. The default is "/usr/bin/glpoptions"
# from ESP Print Pro.
# This option is only used under IRIX; the options panel program
# must accept the "-d printer" and "-o options" options and write
# the selected printer options back to stdout on completion.
#PrintcapGUI /usr/bin/glpoptions
# RequestRoot: the directory where request files are stored.
# By default "/var/spool/cups".
#RequestRoot /var/spool/cups
# RemoteRoot: the name of the user assigned to unauthenticated accesses
# from remote systems. By default "remroot".
#RemoteRoot remroot
# ServerBin: the root directory for the scheduler executables.
# By default "/usr/lib/cups".
#ServerBin /usr/lib/cups
# ServerRoot: the root directory for the scheduler.
# By default "/etc/cups".
#ServerRoot /etc/cups
# ServerTokens: specifies what information in provided in the Server
# header of HTTP responses. The default is Minor.
# ServerTokens None
# ServerTokens ProductOnly CUPS
# ServerTokens Major CUPS/1
# ServerTokens Minor CUPS/1.1
# ServerTokens Minimal CUPS/1.1.23
# ServerTokens OS CUPS/1.1.23 (uname)
# ServerTokens Full CUPS/1.1.23 (uname) IPP/1.1
#ServerTokens Minor
######## Fax Support
# FaxRetryLimit: the number of times a fax job is retried.
# The default is 5 times.
#FaxRetryLimit 5
# FaxRetryInterval: the number of seconds between fax job retries.
# The default is 300 seconds/5 minutes.
#FaxRetryInterval 300
######## Encryption Support
# ServerCertificate: the file to read containing the server's certificate.
# Defaults to "/etc/cups/ssl/server.crt".
#ServerCertificate /etc/cups/ssl/server.crt
# ServerKey: the file to read containing the server's key.
# Defaults to "/etc/cups/ssl/server.key".
#ServerKey /etc/cups/ssl/server.key
######## Filter Options
# User/Group: the user and group the server runs under. Normally this
# must be cupsys and lpadmin, however you can configure things for another
# user or group as needed.
# Note: the server must be run initially as root to support the
# default IPP port of 631. It changes users whenever an external
# program is run, or if the RunAsUser directive is specified...
#User cupsys
#Group lpadmin
# RunAsUser: The RunAsUser directive controls whether the scheduler runs as the
# unpriviledged user account (usually cupsys). The default is No which
# leaves the scheduler running as the root user. However, the Debian package
# was prepared to work as user cupsys, which greatly reduces the impact of
# security holes.
# Note: Running as a non-priviledged user may prevent LPD and locally connected
# printers from working due to permission problems. The lpd backend will
# automatically use a non-priviledged mode that is not 100% compliant with RFC
# 1179. The parallel, serial, and usb backends will need write access to the
# corresponding device files.
RunAsUser Yes
# RIPCache: the amount of memory that each RIP should use to cache
# bitmaps. The value can be any real number followed by "k" for
# kilobytes, "m" for megabytes, "g" for gigabytes, or "t" for tiles
# (1 tile = 256x256 pixels.) Defaults to "8m" (8 megabytes).
#RIPCache 8m
# TempDir: the directory to put temporary files in. This directory must be
# writable by the user defined above! Defaults to "/var/spool/cups/tmp" or
# the value of the TMPDIR environment variable.
#TempDir /var/spool/cups/tmp
# FilterLimit: sets the maximum cost of all job filters that can be run
# at the same time. A limit of 0 means no limit. A typical job may need
# a filter limit of at least 200; limits less than the minimum required
# by a job force a single job to be printed at any time.
# The default limit is 0 (unlimited).
#FilterLimit 0
######## Network Options
# Ports/addresses that we listen to. The default port 631 is reserved
# for the Internet Printing Protocol (IPP) and is what we use here.
# You can have multiple Port/Listen lines to listen to more than one
# port or address, or to restrict access:
# Port 80
# Port 631
# Listen hostname
# Listen hostname:80
# Listen hostname:631
# Listen 1.2.3.4
# Listen 1.2.3.4:631
# NOTE: Unfortunately, most web browsers don't support TLS or HTTP Upgrades
# for encryption. If you want to support web-based encryption you'll
# probably need to listen on port 443 (the "https" port...)
# NOTE 2: In order for the command-line and web interfaces to work, you
# must have at least one Port or Listen line that allows access from the
# local loopback address (localhost).
#Port 80
#Port 443
#Port 631
Listen 127.0.0.1:631
# HostNameLookups: whether or not to do lookups on IP addresses to get a
# fully-qualified hostname. This defaults to Off for performance reasons...
#HostNameLookups On
# KeepAlive: whether or not to support the Keep-Alive connection
# option. Default is on.
#KeepAlive On
# KeepAliveTimeout: the timeout before Keep-Alive connections are
# automatically closed. Default is 60 seconds.
#KeepAliveTimeout 60
# MaxClients: controls the maximum number of simultaneous clients that
# will be handled. Defaults to 100.
#MaxClients 100
# MaxClientsPerHost: controls the maximum number of simultaneous clients that
# will be handled from a specific host. Defaults to 10 or 1/10th of the
# MaxClients setting, whichever is larger. A value of 0 specifies the
# automatic (10 or 1/10th) setting.
#MaxClientsPerHost 0
# MaxRequestSize: controls the maximum size of HTTP requests and print files.
# Set to 0 to disable this feature (defaults to 0.)
#MaxRequestSize 0
# Timeout: the timeout before requests time out. Default is 300 seconds.
#Timeout 300
######## Browsing Options
# Browsing: whether or not to broadcast and/or listen for CUPS printer
# information on the network. For Ubuntu, this setting has been externalized to
# a separate configuration file cupsd-browsing.conf. This allows to change the
# browsing setting with /usr/share/cups/enable_browsing (or manually) without
# modifying this main configuration file, which avoids dpkg questions on
# conffile upgrades.
Include cupsd-browsing.conf
# BrowseProtocols: which protocols to use for browsing. Can be
# any of the following separated by whitespace and/or commas:
# all - Use all supported protocols.
# cups - Use the CUPS browse protocol.
# slp - Use the SLPv2 protocol.
# The default is "cups".
# NOTE: If you choose to use SLPv2, it is *strongly* recommended that
# you have at least one SLP Directory Agent (DA) on your
# network. Otherwise, browse updates can take several seconds,
# during which the scheduler will not respond to client
# requests.
#BrowseProtocols cups
# BrowseAddress: specifies a broadcast address to be used. By
# default browsing information is not sent!
# Note: HP-UX does not properly handle broadcast unless you have a
# Class A, B, C, or D netmask (i.e. no CIDR support).
# Note: Using the "global" broadcast address (255.255.255.255) will
# activate a Linux demand-dial link with the default configuration.
# If you have a LAN as well as the dial-up link, use the LAN's
# broadcast address.
# The @LOCAL address broadcasts to all non point-to-point interfaces.
# For example, if you have a LAN and a dial-up link, @LOCAL would
# send printer updates to the LAN but not to the dial-up link.
# Similarly, the @IF(name) address sends to the named network
# interface, e.g. @IF(eth0) under Linux. Interfaces are refreshed
# automatically (no more than once every 60 seconds), so they can
# be used on dynamically-configured interfaces, e.g. PPP, 802.11, etc.
#BrowseAddress x.y.z.255
#BrowseAddress x.y.255.255
#BrowseAddress x.255.255.255
#BrowseAddress 255.255.255.255
BrowseAddress @LOCAL
#BrowseAddress @IF(name)
# BrowseShortNames: whether or not to use "short" names for remote printers
# when possible (e.g. "printer" instead of "printer@host".) Enabled by
# default.
#BrowseShortNames Yes
# BrowseAllow: specifies an address mask to allow for incoming browser
# packets. The default is to allow packets from all addresses.
# BrowseDeny: specifies an address mask to deny for incoming browser
# packets. The default is to deny packets from no addresses.
# Both "BrowseAllow" and "BrowseDeny" accept the following notations for
# addresses:
# All
# None
# *.domain.com
# .domain.com
# host.domain.com
# nnn.*
# nnn.nnn.*
# nnn.nnn.nnn.*
# nnn.nnn.nnn.nnn
# nnn.nnn.nnn.nnn/mm
# nnn.nnn.nnn.nnn/mmm.mmm.mmm.mmm
# @LOCAL
# @IF(name)
# The hostname/domainname restrictions only work if you have turned hostname
# lookups on!
#BrowseAllow address
#BrowseDeny address
# BrowseInterval: the time between browsing updates in seconds. Default
# is 30 seconds.
# Note that browsing information is sent whenever a printer's state changes
# as well, so this represents the maximum time between updates.
# Set this to 0 to disable outgoing broadcasts so your local printers are
# not advertised but you can still see printers on other hosts.
#BrowseInterval 30
# BrowseOrder: specifies the order of BrowseAllow/BrowseDeny comparisons.
#BrowseOrder allow,deny
#BrowseOrder deny,allow
# BrowsePoll: poll the named server(s) for printers
#BrowsePoll addressort
# BrowsePort: the port used for UDP broadcasts. By default this is
# the IPP port; if you change this you need to do it on all servers.
# Only one BrowsePort is recognized.
#BrowsePort 631
# BrowseRelay: relay browser packets from one address/network to another.
#BrowseRelay source-address destination-address
#BrowseRelay @IF(src) @IF(dst)
# BrowseTimeout: the timeout for network printers - if we don't
# get an update within this time the printer will be removed
# from the printer list. This number definitely should not be
# less the BrowseInterval value for obvious reasons. Defaults
# to 300 seconds.
#BrowseTimeout 300
# ImplicitClasses: whether or not to use implicit classes.
# Printer classes can be specified explicitly in the classes.conf
# file, implicitly based upon the printers available on the LAN, or
# both.
# When ImplicitClasses is On, printers on the LAN with the same name
# (e.g. Acme-LaserPrint-1000) will be put into a class with the same
# name. This allows you to setup multiple redundant queues on a LAN
# without a lot of administrative difficulties. If a user sends a
# job to Acme-LaserPrint-1000, the job will go to the first available
# queue.
# Enabled by default.
#ImplicitClasses On
# ImplicitAnyClasses: whether or not to create "AnyPrinter" implicit
# classes.
# When ImplicitAnyClasses is On and a local queue of the same name
# exists, e.g. "printer", "printer@server1", "printer@server1", then
# an implicit class called "Anyprinter" is created instead.
# When ImplicitAnyClasses is Off, implicit classes are not created
# when there is a local queue of the same name.
# Disabled by default.
#ImplicitAnyCLasses Off
# HideImplicitMembers: whether or not to show the members of an
# implicit class.
# When HideImplicitMembers is On, any remote printers that are
# part of an implicit class are hidden from the user, who will
# then only see a single queue even though many queues will be
# supporting the implicit class.
#HideImplicitMembers On
######## Security Options
# SystemGroup: the group name for "System" (printer administration)
# access. The default varies depending on the operating system, but
# will be "sys", "system", or "root" (checked for in that order.)
# Debian: The default CUPS group is "lpadmin".
#SystemGroup lpadmin
# RootCertDuration: How frequently the root certificate is regenerated.
# Defaults to 300 seconds.
#RootCertDuration 300
# Access permissions for each directory served by the scheduler.
# Locations are relative to DocumentRoot...
# AuthType: the authorization to use:
# None - Perform no authentication
# Basic - Perform authentication using the HTTP Basic method.
# Digest - Perform authentication using the HTTP Digest method.
# (Note: local certificate authentication can be substituted by
# the client for Basic or Digest when connecting to the
# localhost interface)
# AuthClass: the authorization class; currently only "Anonymous", "User",
# "System" (valid user belonging to group SystemGroup), and "Group"
# (valid user belonging to the specified group) are supported.
# AuthGroupName: the group name for "Group" authorization.
# Order: the order of Allow/Deny processing.
# Allow: allows access from the specified hostname, domain, IP address,
# network, or interface.
# Deny: denies access from the specified hostname, domain, IP address,
# Both "Allow" and "Deny" accept the following notations for addresses:
# All
# None
# *.domain.com
# .domain.com
# host.domain.com
# nnn.*
# nnn.nnn.*
# nnn.nnn.nnn.*
# nnn.nnn.nnn.nnn
# @LOCAL
# @IF(name)
# The host and domain address require that you enable hostname lookups
# with "HostNameLookups On" above.
# The @LOCAL address allows or denies from all non point-to-point
# interfaces. For example, if you have a LAN and a dial-up link,
# @LOCAL could allow connections from the LAN but not from the dial-up
# link. Similarly, the @IF(name) address allows or denies from the
# named network interface, e.g. @IF(eth0) under Linux. Interfaces are
# refreshed automatically (no more than once every 60 seconds), so
# they can be used on dynamically-configured interfaces, e.g. PPP,
# 802.11, etc.
# Encryption: whether or not to use encryption; this depends on having
# the OpenSSL library linked into the CUPS library and scheduler.
# Possible values:
# Always - Always use encryption (SSL)
# Never - Never use encryption
# Required - Use TLS encryption upgrade
# IfRequested - Use encryption if the server requests it
# The default value is "IfRequested".
<Location />
Order Deny,Allow
Deny From All
Allow From 127.0.0.1
</Location>
#<Location /classes>
# You may wish to limit access to printers and classes, either with Allow
# and Deny lines, or by requiring a username and password.
#</Location>
#<Location /classes/name>
#</Location>
<Location /jobs>
# You may wish to limit access to job operations, either with Allow
AuthType Basic
AuthClass User
</Location>
#<Location /printers>
#</Location>
#<Location /printers/name>
## Anonymous access (default)
#AuthType None
## Require a username and password (Basic authentication)
#AuthType Basic
#AuthClass User
## Require a username and password (Digest/MD5 authentication)
#AuthType Digest
#AuthClass User
## Restrict access to local domain
#Order Deny,Allow
#Deny From All
#Allow From .mydomain.com
#</Location>
<Location /admin>
# You definitely will want to limit access to the administration functions.
# The default configuration requires a local connection from a user who
# is a member of the system group to do any admin tasks. You can change
# the group name using the SystemGroup directive.
AuthType Basic
AuthClass System
Order Deny,Allow
Deny From All
#Encryption Required
</Location>
mehulved is offline
Old 07-02-2006, 01:19 AM   #8 (permalink)
El mooooo
eddie's Avatar
Did it work in Knoppix? How many parallel ports do you have on your system? Do you have proper permissions on /dev/lp0? Change LogLevel in cupsd.conf to debug2 and then try printing again. After it fails, check in /var/log/cups/error_log to see what errors it gives.
eddie is offline
Old 07-02-2006, 01:24 AM   #9 (permalink)
It doesn't work in either.
I have only 1 parallel port on my computer.
Yeah I have proper permissions.
I will try what you've suggested and check.
mehulved is offline
Old 07-02-2006, 01:31 AM   #10 (permalink)
Here the result of error_log
I [06/Feb/2006:20:31:07 +0530] Listening to 7f000001:631
I [06/Feb/2006:20:31:07 +0530] Loaded configuration file "/etc/cups/cupsd.conf"
I [06/Feb/2006:20:31:07 +0530] Configured for up to 100 clients.
I [06/Feb/2006:20:31:07 +0530] Allowing up to 100 client connections per host.
I [06/Feb/2006:20:31:07 +0530] Full reload is required.
E [06/Feb/2006:20:31:07 +0530] LoadAllPrinters: Unable to open /etc/cups/printers.conf - No such file or directory
E [06/Feb/2006:20:31:07 +0530] LoadAllClasses: Unable to open /etc/cups/classes.conf - No such file or directory
I [06/Feb/2006:20:31:15 +0530] LoadPPDs: Wrote "/etc/cups/ppds.dat", 4104 PPDs...
I [06/Feb/2006:20:31:15 +0530] Full reload complete.
I [06/Feb/2006:20:32:22 +0530] Scheduler shutting down normally.
I [06/Feb/2006:20:32:22 +0530] Listening to 7f000001:631
I [06/Feb/2006:20:32:22 +0530] Loaded configuration file "/etc/cups/cupsd.conf"
I [06/Feb/2006:20:32:22 +0530] Configured for up to 100 clients.
I [06/Feb/2006:20:32:22 +0530] Allowing up to 100 client connections per host.
I [06/Feb/2006:20:32:22 +0530] Full reload is required.
E [06/Feb/2006:20:32:22 +0530] LoadAllPrinters: Unable to open /etc/cups/printers.conf - No such file or directory
E [06/Feb/2006:20:32:22 +0530] LoadAllClasses: Unable to open /etc/cups/classes.conf - No such file or directory
I [06/Feb/2006:20:32:24 +0530] LoadPPDs: Read "/etc/cups/ppds.dat", 4104 PPDs...
I [06/Feb/2006:20:32:24 +0530] LoadPPDs: No new or changed PPDs...
I [06/Feb/2006:20:32:24 +0530] Full reload complete.
I [06/Feb/2006:20:36:37 +0530] Scheduler shutting down normally.
I [06/Feb/2006:20:36:37 +0530] Listening to 7f000001:631
I [06/Feb/2006:20:36:37 +0530] Loaded configuration file "/etc/cups/cupsd.conf"
I [06/Feb/2006:20:36:37 +0530] Configured for up to 100 clients.
I [06/Feb/2006:20:36:37 +0530] Allowing up to 100 client connections per host.
I [06/Feb/2006:20:36:37 +0530] Full reload is required.
E [06/Feb/2006:20:36:37 +0530] LoadAllPrinters: Unable to open /etc/cups/printers.conf - No such file or directory
E [06/Feb/2006:20:36:37 +0530] LoadAllClasses: Unable to open /etc/cups/classes.conf - No such file or directory
I [06/Feb/2006:20:36:39 +0530] LoadPPDs: Read "/etc/cups/ppds.dat", 4104 PPDs...
I [06/Feb/2006:20:36:41 +0530] LoadPPDs: No new or changed PPDs...
I [06/Feb/2006:20:36:41 +0530] Full reload complete.
I [07/Feb/2006:01:22:13 +0530] Setting i255-ver.2.3 device-uri to "canon:/dev/lp0" (was "file:/dev/null".)
I [07/Feb/2006:01:22:13 +0530] Setting i255-ver.2.3 printer-is-accepting-jobs to 1 (was 0.)
I [07/Feb/2006:01:22:13 +0530] Setting i255-ver.2.3 printer-state to 3 (was 5.)
E [07/Feb/2006:01:22:13 +0530] Unable to backup printers.conf - No such file or directory
I [07/Feb/2006:01:22:13 +0530] Saving printers.conf...
I [07/Feb/2006:01:22:13 +0530] New printer 'i255-ver.2.3' added by 'root'.
I [07/Feb/2006:01:22:56 +0530] Adding start banner page "none" to job 1.
I [07/Feb/2006:01:22:56 +0530] Adding end banner page "none" to job 1.
I [07/Feb/2006:01:22:56 +0530] Job 1 queued on 'i255-ver.2.3' by 'mehul'.
I [07/Feb/2006:01:22:56 +0530] Started filter /usr/lib/cups/filter/pstops (PID 9467) for job 1.
I [07/Feb/2006:01:22:56 +0530] Started filter /usr/lib/cups/filter/pstocanonbj (PID 9468) for job 1.
I [07/Feb/2006:01:22:56 +0530] Started backend /usr/lib/cups/backend/canon (PID 9469) for job 1.
E [07/Feb/2006:01:22:56 +0530] PID 9468 stopped with status 22!
I [07/Feb/2006:01:22:56 +0530] Hint: Try setting the LogLevel to "debug" to find out more.
I [07/Feb/2006:01:28:39 +0530] Adding start banner page "none" to job 2.
I [07/Feb/2006:01:28:39 +0530] Adding end banner page "none" to job 2.
I [07/Feb/2006:01:28:39 +0530] Job 2 queued on 'i255-ver.2.3' by 'mehul'.
I [07/Feb/2006:01:28:39 +0530] Started filter /usr/lib/cups/filter/pstops (PID 9618) for job 2.
I [07/Feb/2006:01:28:39 +0530] Started filter /usr/lib/cups/filter/pstocanonbj (PID 9619) for job 2.
I [07/Feb/2006:01:28:39 +0530] Started backend /usr/lib/cups/backend/canon (PID 9620) for job 2.
E [07/Feb/2006:01:28:39 +0530] PID 9619 stopped with status 22!
I [07/Feb/2006:01:28:39 +0530] Hint: Try setting the LogLevel to "debug" to find out more.
If you can find anything do tell me. I can't understand if antything is going wrong.
mehulved is offline
Old 07-02-2006, 01:53 AM   #11 (permalink)
El mooooo
eddie's Avatar
looks like you didn't restart cups after editing cupsd.conf. you need to do that.
eddie is offline
Old 07-02-2006, 02:19 AM   #12 (permalink)
Tried that but still no response from the printer.
mehulved is offline
Old 07-02-2006, 02:56 AM   #13 (permalink)
El mooooo
eddie's Avatar
i meant that changing the LogLevel to debug2 will only work after you have restarted cups. Now there should be extra entries in error_log. I would like to see those entries. Also post the output of
ls -l /dev/lp0
ls -l /dev/printers/0
eddie is offline
Old 07-02-2006, 03:26 AM   #14 (permalink)
El mooooo
eddie's Avatar
I searched for this printer and all the hits I am getting, tell me that this particular printer is a USB one. Are you sure it is connected to Parallel Port?
eddie is offline
Old 07-02-2006, 03:27 AM   #15 (permalink)
/dev/lp0 had permission or read and write and not execute. /dev/printer/0 or anything similar doesn't exist.
mehulved is offline
Old 07-02-2006, 03:30 AM   #16 (permalink)
All right then I will try to check every USB port. I can't check it physically as the back of my PC isn't reachable now.
mehulved is offline
Old 07-02-2006, 03:34 AM   #17 (permalink)
El mooooo
eddie's Avatar
Just turn on the printer and then pass the command lsusb. It should tell you the USB port, the printer is connected to. If Ubuntu is using udev then you can also launch udevmonitor in a terminal window and then start the printer. It will give you even more verbose output.
eddie is offline
Old 07-02-2006, 03:38 AM   #18 (permalink)
OK somehow the printer got autodetected now. Its on USB 1. Thanks a lot out there. I dunno why it wasn't detected at first. But, still whenever I give print a test page command, there's no response from the printer.
mehulved is offline
Old 08-02-2006, 12:14 AM   #19 (permalink)
El mooooo
eddie's Avatar
Did you change the URI? Time to post printers.conf and error_log again. Please don't attach them here. Instead upload them some place and then just link them here.
eddie is offline
Old 08-02-2006, 12:47 AM   #20 (permalink)
Here they are
http://rapidshare.de/files/12761245/printer.conf.html
http://rapidshare.de/files/12761676/error_log.html
inform me if the second file is wrong
Hope you can access rapidshare or else tell me any other sites where I can upload my files.
mehulved is offline
Old 08-02-2006, 02:00 AM   #21 (permalink)
El mooooo
eddie's Avatar
Hmm..Didn't get much info there. Lets try once again. Change the LogLevel from debug2 to debug in cupsd.conf. Delete error_log and restart cups. Try printing again and then send me error_log again. Remember to restart cups only after you've deleted error_log.
eddie is offline
Old 08-02-2006, 02:17 AM   #22 (permalink)
Here the new error_log http://rapidshare.de/files/12767810/error_log.html
mehulved is offline
Old 08-02-2006, 02:42 AM   #23 (permalink)
El mooooo
eddie's Avatar
D [08/Feb/2006:02:12:19 +0530] [Job 4] /usr/lib/cups/filter/pstocanonbj: No such file or directory
Is the driver properly installed?
What does "ls -l /usr/lib/cups/filter/pstocanonbj" give you?
eddie is offline
Old 08-02-2006, 03:02 AM   #24 (permalink)
I get the correct driver name in the printer properties. BTW, I can't find the file you're asking for. In /usr/lib/cups/filter/ I can find following files with similar names:- pstoplx, pstoraster, commandtocanon.
mehulved is offline
Old 08-02-2006, 10:32 AM   #25 (permalink)
El mooooo
eddie's Avatar
Looks like the package that you installed, installs driver in a different location to what CUPS is looking for. run "updatedb" and then "locate pstocanonbj" to find where the filter is.
eddie is offline
Old 08-02-2006, 09:47 PM   #26 (permalink)
I did as you've asked me to do but "locate pstocanonbj" doesn't give any results. It just executes but there's no output at the console.
mehulved is offline
Old 08-02-2006, 09:51 PM   #27 (permalink)
I don't know much abt these
I think you can try http://localhost:631
on ur browser
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die!
naveenchandran is offline
Old 08-02-2006, 09:57 PM   #28 (permalink)
Tried your solution naveenchandran but it asks for cups password. Will look at that too after sometime.
mehulved is offline
Old 09-02-2006, 12:34 AM   #29 (permalink)
El mooooo
eddie's Avatar
You definitely seem to be missing some part of the driver. Did you install all the packages for your printer from here?
http://www.canon.co.nz/products/prin...0_drivers.html
Also I found this link
http://www.linuxprinting.org/piperma...q1/002031.html
Even though it is about i250, it *should* work with i255 as well. Give it a try.
To enable CUPS web interface in Ubuntu, have a look here.
http://ubuntu.wordpress.com/2005/10/...min-interface/
eddie is offline
Old 09-02-2006, 02:21 AM   #30 (permalink)
I installed the files as of what I saw in the second link provided by you. So, now I can see pstocanonbj. Still no respons from the printer.
mehulved is offline
