Old 03-02-2006, 11:05 AM   #1 (permalink)
Default configuring network settings in linux through LAN card
I have p3 system with a LAN card
i have cable net connection
i 'm able to use it in win XP but not in LINUX
which is my second OS
can any one tell me how do i connect to internet in LINUX
the LINUX is RED HAT LINUX 9.0
OR
please mail to sunil19@gmail.com
sunil.p is offline
Old 03-02-2006, 11:23 AM   #2 (permalink)
left this forum longback
praka123's Avatar
check the sticky on configuring dataone in this forum.perhaps it will help.U may need to set ur IP address G/W mask etc either DHCP or static
praka123 is offline
Old 04-02-2006, 07:58 PM   #3 (permalink)
i did all that but there is no effect
it either says connection is refused to ...
or
says that cannot connect ...
sunil.p is offline
Old 04-02-2006, 08:33 PM   #4 (permalink)
El mooooo
eddie's Avatar
Post the output of "ifconfig eth0". The command needs to be run as root.
eddie is offline
