| Forum |
#1 (permalink) |
i have project of developing accounting/inventory/payroll system for small company. I have the choice of selecting softwares. Presently they r using windows xp,(few pirated ones). Users r ready to switch to free linux version. I am thinking of going for MYSQL and PHP, but my problem is, will users be comfortable with browser based softwares, since all systems are in local network, going for desktop version will not be a better choice? Is there any software for developing desktop version in linux using mysql. I have heard of python, is it same as VB or delphi. looking at above problems, i think , it will be better to go for MS Sql Server (free express edtion) and ASP/ Delph/VB for developing both versions - browser based as well as desktop version. Please suggest best solution . thankssss |
#2 (permalink) |
You can use GTK+/Qt and MySQL for developing desktop applocations. Both are Free Softwares, Portable and Platform independant.
You may wanna give a try in Mono/dotgnu also.
Sometime you'll think you understand everything ...Then you'll regain consciousness |
#3 (permalink) | |
otherwise u can also go for JSP/MySQL or JSP/Oracle and u can use IBM WSAD for that, it's the best java IDE i have seen.............
Music is like Sex, The more you get, the more you want. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
