Old 25-01-2006, 10:51 PM   #1 (permalink)
Default username & password problem in oracle 10g,pls help !!!
hi guys
today i've downloaded oracle 10g & installed on my pc but when im trying to open sql plus a username & password query comes in ,in my collg sir told to use scott & tiger as username & password but its not working .
if any1 know pls help me!!!
mine weapons down ...
gycapri is offline
Old 26-01-2006, 08:03 AM   #2 (permalink)
vignesh's Avatar
Is it the free linux version or for wndows ?
vignesh is offline
Old 26-01-2006, 01:07 PM   #3 (permalink)
this1 is only for windows 32 bit but for linux its versions r given for download .
but my problem remains same ...
gycapri is offline
Old 26-01-2006, 02:49 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
the username is system
and the password is the one u give while installation
vijay_7287 is offline
Old 26-01-2006, 08:17 PM   #5 (permalink)
username is correct but wats password???
i left the option of password blank at the time of installation .
so wat i do now????
i tried username & passwords ,also blank1 but nothing worked.
wat now i do???
gycapri is offline
Old 26-01-2006, 08:24 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
in the first place,
i dont think u can leave it blank
since u hav downloaded it
reinstall it with a password and it will be done
Old 27-01-2006, 06:45 PM   #7 (permalink)
k,
this is the way to go,
u can try
system/manager
scott/tiger
but first u need to make sure that oracle instance is running if it's not running u wouldn't ever be able to connect SQL,
If it's not running then also let me know i'll tell u hw to do that also.
and pls next time let me know ur system config also...
hope this works(But i think u have instance or memory problem coz scott/tiger should work)
Music is like Sex, The more you get, the more you want.
demoninside is offline
