Old 20-01-2006, 11:16 AM   #1 (permalink)
Default Alias Does Not Work In Shell Script
When I tried to use alias in shell script, it didn't work.
This will clearify what I mean:-
#!/bin/bash
alias hello='echo Hello, how are you?'
hello
#end of shell script
If this shell script is run it will give an error message stating that the command hello was not found.
Why does this happen? Wasn't the alias command executed? Then why hello was not aliased?
mannahazarika is offline
Old 20-01-2006, 08:46 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Alias Does Not Work In Shell Script
but you can have it run on sh?
prakash@suryan:~/Desktop$ vi hello
prakash@suryan:~/Desktop$ sh hello
Hello,How are You?
this will be the soltn..
prakash@suryan:~$ vi Desktop/hello
#! /bin/bash
shopt -s expand_aliases
alias hello='echo Hello,How are You?'
hello
echo
exit
prakash@suryan:~$ Desktop/hello
Hello,How are You?
prakash@suryan:~$
praka123 is offline
Old 24-01-2006, 05:29 PM   #3 (permalink)
String Phreak
mediator's Avatar
#!/bin/bash
hello
The syntax is wrong dood!
try as..
alias hello='echo "Hello, how are you?"'
then try hello
the syntax between ' ' is a shell command in ur case is echo "Hello, how are you?"
mediator is offline
Old 24-01-2006, 05:48 PM   #4 (permalink)
You need to add this line to your script to make bash expand aliases in it -
mediator, that should not matter, echo echoe's whatever arguments is provided to it, whether quoted together or not.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
