Why dont you apply for an
HP - Testdrive shell account? <
http://www.testdrive.hp.com >
They provide following Linux/UNIX/OpenVMS/BSD/HP-UX servers available to you, once your account is accepted. You can then telnet inside and test your shell script on various hardware and operating system combinations.
Hewlett Packard OS Test Drives:
Test Drive System Type How to access
HP Tru64 Unix 5.1b(JAVA) Alpha DS15 2@1.0GHz(ev68) telnet to td158.testdrive.hp.com
HP Tru64 Unix 5.1b(JAVA) Alpha ES45 4@1GHz (ev68) telnet to td208.testdrive.hp.com
HP Tru64 Unix 5.1b(JAVA) Alpha ES47 2@1GHz (ev7) telnet to td171.testdrive.hp.com
HP OpenVMS 8.2 Alpha ES45 4@1GHz (ev68) telnet to td180.testdrive.hp.com
HP OpenVMS 8.2 Alpha DS10L 466MHz (ev6) telnet to td202.testdrive.hp.com
HP OpenVMS 8.2-1 Integrity rx1620 2@1.6GHz telnet to td183.testdrive.hp.com
HP-UX 11i 11.11 rp2470 2@750MHz 8700 PA-RISC telnet to td192.testdrive.hp.com
HP-UX 11i v2 rp3410 2@800MHz 8800 PA-RISC telnet to td191.testdrive.hp.com
HP-UX 11i v2 Integrity rx1620 2@1.6GHz telnet to td176.testdrive.hp.com
Linux Test Drives:
Debian GNU/Linux 3.1r0 on Intel ProLiant DL360 G2 1.4GHz (P3) telnet to td140.testdrive.hp.com
Debian GNU/Linux 3.1r0 on Intel Integrity rx2600 2@900MHz telnet to td156.testdrive.hp.com
Debian GNU/Linux 3.1r0 on Alpha Alpha DS20 2@500MHz (ev6) telnet to td161.testdrive.hp.com
Red Hat Ent Linux ES 4.0 on Intel ProLiant ML530 2@1.0GHz (P3) telnet to td141.testdrive.hp.com
Red Hat Ent Linux AS 4.0 on Intel ProLiant BL20p 2@3.0GHz(Xeon) telnet to td163.testdrive.hp.com
Red Hat Ent Linux AS 4.0 on Intel ProLiant DL560 4@3.0GHz(Xeon) telnet to td185.testdrive.hp.com
Red Hat Ent Linux AS 4.0 on AMD ProLiant DL145 2.2GHz(Opteron)telnet to td189.testdrive.hp.com
Red Hat Ent Linux AS 4.0 on Intel Integrity rx1620 2@1.6GHz telnet to td177.testdrive.hp.com
Red Hat Ent Linux AS 4.0 on Intel Integrity rx8620 16@1.5GHz telnet to td178.testdrive.hp.com
SuSE Linux Ent Svr 9.0 on Intel ProLiant BL20p 2@3.0GHz(Xeon) telnet to td162.testdrive.hp.com
SuSE Linux Ent Svr 9.0 on Intel ProLiant DL140 2@3.2GHz(Xeon) telnet to td186.testdrive.hp.com
SuSE Linux Ent Svr 9.0 on AMD ProLiant DL145 2.2GHz(Opteron)telnet to td190.testdrive.hp.com
SuSE Linux Ent Svr 9.0 on AMD ProLiant DL585 2.2GHz(Opteron)telnet to td179.testdrive.hp.com
SuSE Linux Ent Svr 9.0 on Intel Integrity rx2600 2@900 Mhz telnet to td187.testdrive.hp.com
BSD Test Drives:
FreeBSD 6.0 on Intel Integrity rx1620 2@1.6GHz telnet to td150.testdrive.hp.com
FreeBSD 5.4 on Intel ProLiant DL360 2@1.4GHz (P3) telnet to td152.testdrive.hp.com
FreeBSD 6.0 on Alpha Alpha XP1000a 1@667MHz (ev6) telnet to td149.testdrive.hp.com
NetBSD 2.0 on Intel ProLiant DL360 2@1.2GHz (P3) telnet to td143.testdrive.hp.com
Cluster Test Drives:
HP Cluster Platform CP6000 Integrity rx2600x8 1.3GHz telnet to td146.testdrive.hp.com
HP OpenVMS Galaxy Cluster 8.2 Alpha ES40 2@500MHz telnet to td181.testdrive.hp.com
telnet to td182.testdrive.hp.com
Application Test Drives:
Oracle Rdb on OpenVMS Alpha DS20 2@500MHz (ev6) telnet to td180.testdrive.hp.com
Oracle Rbd on OpenVMS Integrity rx1620 2@1GHz telnet to td183.testdrive.hp.com
