Old 26-12-2005, 12:25 PM   #1 (permalink)
Default Problem in Installing SUSE Linux pro 10
My monitor is not in the list . It is samsung syncmaster 753 s . I tried similar ones but no result, screen goes blank. Also what is the correct resolution to be given?
sarincv is offline
Old 26-12-2005, 05:11 PM   #2 (permalink)
desertwind's Avatar
Try Manual settings as below.
Horizontal Frequency - 30-70 kHz
Vertical Frequency - 50 - 160 Hz
Maximum Resolution - 1280 x 1024 @ 65Hz
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 26-12-2005, 05:45 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
@ author - choose the generic/general type of monitor, install and then follow what Desertwind has said
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-12-2005, 09:53 PM   #4 (permalink)
Satissh S's Avatar
Yikes!! It's my monitor..
Just scroll down the list in the monitor section and select
Samsung SyncMaster 753 (DF) Magic SyncMaster
Make Sure that Horizsync 30-70 and vertrefresh 50-160 in the /etc/X11/xorg.conf File.
Rest will fall in it's place automatically..
Satissh S is offline
Old 30-12-2005, 11:11 AM   #5 (permalink)
Thank you .I will try wha u said
sarincv is offline
