Old 23-12-2005, 01:35 PM   #1 (permalink)
mohit sharma's Avatar
Default sourse codes of linuxes
open source means source codes are open
but is there any site from which i can download entire souse code of any linux ??
by the way which language is preflably used for making any linux ??
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
mohit sharma is offline
Old 23-12-2005, 01:59 PM   #2 (permalink)
left this forum longback
praka123's Avatar
thats waht you r compiling from source means..and u really wanna try source
compiling try gentoo gnu/Linux...it comes in source compressed as tar balls..
and kernel.org holds the kernel sources...Linux Kernel mostly uses C language....
praka123 is offline
Old 23-12-2005, 02:05 PM   #3 (permalink)
You can get the source code of the linux kernel from www.kernel.org , source code of the shells, utilities and other things can be got from various websites, like www.gnu.org
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 23-12-2005, 08:13 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
Navigate to http://www.debian.org/distrib/packages#search_packages
and enter the name for your package. From there you can download sources for almost 17k+ packages available with debian
http://web.gnuer.org
GNUrag is offline
