Old 16-12-2005, 06:05 PM   #1 (permalink)
Default linux installaion problem??
I got a P4 with HT 3.0ghz. 915gav motherboard. sata rive 80gb. When i try to install redhat linux v9 i get the following message no harddisk found .Please help!!!
faraz_majidkhan is offline
Old 16-12-2005, 06:48 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
r u sure tht the HD is connected properly and configured
try with diff linux distro
even i got a prob with FC4
i suggest u will be better served on this in the open source section !!!
vijay_7287 is offline
Old 16-12-2005, 09:18 PM   #3 (permalink)
desertwind's Avatar
Most probably you'll be using SATA HDD, which unfortunately is not supported by Older versions of linux kernel.
And RH9 is pretty old. I suggest you to use some newer distros like FC4/OpenSuSE/Ubuntu Breezy Badger.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 16-12-2005, 09:43 PM   #4 (permalink)
left this forum longback
praka123's Avatar
RH9 with 2.4 kernel will not support get distros with kernel 2.6 ...
praka123 is offline
Old 19-12-2005, 05:58 PM   #5 (permalink)
thanks for the replies! I will try other distributions.
Old 19-12-2005, 06:10 PM   #6 (permalink)
Satissh S's Avatar
it's best to try fedora..
Satissh S is offline
Old 19-12-2005, 06:23 PM   #7 (permalink)
SATA is not supported By RH9
so try some New distro,
nd u r having a good config system, why r u going for old distro.............
Music is like Sex, The more you get, the more you want.
demoninside is offline
