Old 06-12-2005, 04:27 PM   #1 (permalink)
18 Till I Die............
Default Problem with internet connection in debian sarge
I am having problem accessing internet in debian sarge. Everything was working fine till 15 mins back. But, all of a sudden I started getting no connection. It happened while I was adding SMTP server settings for thuderbird(dunno if there's some connection between the two).
But, the strange thing is that I can ping both my IP and Gateway. Also, I don't think DNS server is down either cos I can access digit forums without any problems. I can get my mail from my ISP's POP server. But, I can't connect to yahoo or amsn messenger.
Any idea what's gone wrong?
My IP, Gateway and DNS settings are OK.
http://www.bash.org/?258908
mehulved is offline
Old 06-12-2005, 07:13 PM   #2 (permalink)
left this forum longback
praka123's Avatar
are u having pppoe or dial-up...assumes pppoe
try 'ifconfig' for lan up or not ...otherwise 'ifconfig eth0 up' and try...
sometimes if u assume ipaddress,gateways etc for lan,u may need to run
'route add default ppp0' or whatever the connx name is...AFTER 'pon dsl-provider'....taking ur word 'no connection'
praka123 is offline
Old 06-12-2005, 09:51 PM   #3 (permalink)
Thanks prakash. I dunno what caused the problem but one simple reboot did the trick.
mehulved is offline
