Old 26-11-2005, 09:43 PM   #1 (permalink)
Default Problem in monitor
Hi all,
I am using Red Hat 9.0 , my problem is my desktop is not covered fully.
only after 1/2 cm the left margin of desktop begins , so i feel uncomfortable to access the close window buttons when i maximize a window .
My monitor is not automatically detected by Red hat .
Please tell me how to sort out this problem ?
Thanks
m.parthiban is offline
Old 26-11-2005, 11:44 PM   #2 (permalink)
On the monitor there are buttons to resize the screen,use them
rachitar is offline
Old 27-11-2005, 01:25 PM   #3 (permalink)
Mate thanks for your reply.
I am having dual OS . I tried the option u told already , if i change then the problem switch over to Windows OS .
Please Tell me any other alternative solution .
Old 27-11-2005, 02:11 PM   #4 (permalink)
Even i had the same problem but once i adjusted the settings in Linux,it didnt affect in Windows
rachitar is offline
Old 27-11-2005, 02:45 PM   #5 (permalink)
left this forum longback
praka123's Avatar
For ur problem regrding monitor u need to edit Xfree86 conf file,in /etx/X11/XF86CONFIG(for debian used rh 7.2 longback) and find the line like this
Section "Monitor"
        Identifier      "S/T 57/56E/V"
        Option          "DPMS"
        HorizSync       30-55
        VertRefresh     50-120
EndSection
refer ur monitor manual for correct hor and vert frequency enter there.restart x server...
praka123 is offline
