Old 26-11-2005, 07:17 PM   #1 (permalink)
Default problem while installing Wine in Red hat 9.0
Hi all,
I try to install Wine RPM in redhat 9.0 , but while installing it fails with dependency and it says
" glibc >= 2.3.2-27.9.7 is needed by wine-0.9.1-1rh9winehq"
I checked glibc is already installed are not using rpm -q glibc then i got installed information
as follows
glibc-2.3.2-11.9
What is the problem ? Please tell me how to install Wine and use it.
Thanks
m.parthiban is offline
Old 26-11-2005, 08:29 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Get an updated glibc from repo..install as rpm -Uvh sdsd.rpm
praka123 is offline
Old 26-11-2005, 09:40 PM   #3 (permalink)
Default Tell me the link where i can get
Thanks for your reply . Please tell me the link where i can download .
Old 26-11-2005, 11:14 PM   #4 (permalink)
desertwind's Avatar
It's very clear that you've glibc-2.3.2-11.9, but wine requires 2.3.2-27.9.7 which is a higher version.
Use the following command to update
$ yum update glibc
This will handle all dependancies too.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 27-11-2005, 01:21 PM   #5 (permalink)
Means i have to download a updated version ?
If yes means Please give me link where i can get it.
I dont have yum . can i use command rpm -Uvh to update it ?
Old 27-11-2005, 01:47 PM   #6 (permalink)
desertwind's Avatar
you'll have yum by default. If not install yum from you installation disc.
The problem with downloading a single rpm file is that you may face some dependancies, which needs you to download another file. yum handles it all. Thats the best way.
http://rpm.pbone.net/index.php3/stat....i386.rpm.html
here's the link you needed. But i suggest you to use yum.
