Old 26-11-2005, 05:15 PM   #1 (permalink)
abracadabra's Avatar
Default help on LINUX for LAPTOPS
members i need a help for a good linux for my newly brought laptop as did not have any preloaded oses. preferably do give me a good reliable one that has probably a good forum support
abracadabra is offline
Old 26-11-2005, 08:16 PM   #2 (permalink)
left this forum longback
praka123's Avatar
I think Ubuntu breezy is what fits ur need,perhaps simply mepis also will do...
if u want full distros(gnome+kde+...) try Fedora core 4 or Suse 9.3/opensuse 10.0
praka123 is offline
Old 26-11-2005, 08:52 PM   #3 (permalink)
Try Ubuntu
Fedora is too heavy on the system
rachitar is offline
Old 26-11-2005, 09:31 PM   #4 (permalink)
vignesh's Avatar
Breezy or Fedora is the best option....What laptop do you have by the way?
vignesh is offline
Old 27-11-2005, 09:09 PM   #5 (permalink)
18 Till I Die............
Though I haven't used it I've heard a lot about Ubuntu and seems a great one.
Suse 10 is also great. I've used OpenSuse 10.0. Gives a good performance.
Also Fedora is good and easy.
I would say first choice Ubuntu.
http://www.bash.org/?258908
mehulved is offline
Old 27-11-2005, 09:53 PM   #6 (permalink)
vignesh's Avatar
Ubuntu has a special version for Hp laptops too...
vignesh is offline
Old 27-11-2005, 10:28 PM   #7 (permalink)
i would recommend gentoo. Its a bit difficult to load initially but works out beautfully at end. I use it on my tosiba tecra s2 no problems till date.
**** happens
pradeep_chauhan is offline
Old 28-11-2005, 09:35 AM   #8 (permalink)
vignesh's Avatar
Do you know how to install gentoo 4.2 on a pc..The compile instructions.I would likr to try it.
vignesh is offline
Old 13-12-2005, 12:41 PM   #9 (permalink)
Go in for Ubuntu its the best for ur needs and is very easy to setup and use and it dosent suck on the battery life of ur Laptop, where as on the other Gentoo is a bit hard to setup( atleast i think so coz i had some problem with it) but if u get running then it works just as good as ne other distro
fighting for peace is like ****ing for virginity
cryptid is offline
Old 13-12-2005, 12:48 PM   #10 (permalink)
vignesh's Avatar
Ubuntu has a special edition for Hp laptops....
vignesh is offline
