18-11-2005, 03:28 PM
xine not installing properly...
I installed xine-lib1.0.3 but the xine-ui0.99 is not installing.
While i try to configure xine-ui i got an error that xine-lib is not installed. Actually i installed xine-lib and then tried to configure xine-ui but in vain i got the above error.
I included the path where the xine is installed in
but still xine-ui didnt configure...
I am using RHEL 4
18-11-2005, 04:39 PM
Download all the 3 rpms and put them in the same folder and give the command
rpm ivh* * --nodeps
18-11-2005, 05:09 PM
From where will you get the rpm's for xine cos i tried searching it in xinehq.de but didnt find it there...
18-11-2005, 05:26 PM
Sometime you'll think you understand everything
...Then you'll regain consciousness
18-11-2005, 07:38 PM
left this forum longback
I installed Xine in Ubuntu breezy,it's a real pain.as i searched their universal section apt-get fails with no libxine1c2 library.@tlASt installed debian Xine .debs and played with all deps and got xine somehow playing,,...
18-11-2005, 08:40 PM
Thanks for the link of rpm's. I installed it but when i try to run it through terminal i am getting error like -
xine: error while loading shared libraries: libXv.so.1: cannot open shared object file: No such file or directory
I tried to install
xorg-x11-libs-6.8.2-1.FC3.13_2.rhfc3.at.i386.rpm
but i got conflicts for it...
How can i use now...
19-11-2005, 12:10 AM
...I tried to install
did u tried updating the rpm?(rpm -Uvh ..rpm)
even google shows umpteen results for same error u got..
http://rpm.sh-linux.org/rpm-index-2004/libXv.so.1.html
19-11-2005, 07:32 AM
Try freshrpms.net
19-11-2005, 08:49 AM
even for update it showed conflicts...
19-11-2005, 12:18 PM
first remove the xorg rpm (if needed give --nodeps),xine-libs etc.try reinstall,first try installing xine-ui ,which will show needed dependencies.install the dependencies one by one.if again conflict shows up try 'rpm -ivh foo.rpm --force' .also AFAIK for xine to play wmv files,u must install win32codecs
http://atrpms.net/dist/common/w32codec/
In xine gui setup option u can get lot of options....
consider mplayer also.gr8 player,got browser plugins also(mozplugger..).
http://atrpms.net/dist/fc3/mplayer/
also if u have installed bash-completion rpm it will help u by double clicking the tab button showing the instaled rpms,files etc..(FYI)
http://atrpms.net/dist/common/bash-completion/
20-11-2005, 09:11 AM
I have tried to play a file directly from the CD in MPLAYER and even xine(xine is working fine now, thanks for everything), but i got an error in MPLAYER as "this file format is not supported" and in case of xine "its not a valid MRL".
How to give a VAILD mrl now.
20-11-2005, 11:54 AM
i've got prob in mplayer
i 've got prob on mplayer installation.
can anybody help me.
20-11-2005, 04:16 PM
Tell us the problem...
20-11-2005, 04:23 PM
Perhaps win32codecs or mplayer-codecs-win32 needs to be installed for mplayer to play some formats...
20-11-2005, 08:55 PM
How to use both mplayer and xine directly from the cdrom?
21-11-2005, 04:56 PM
@pai
wat do u mean?In CP u got VCD/DVD etx..options are there..?OR
automatically opening DVD/VCD by Xine?
21-11-2005, 07:21 PM
@pai
I tried doing it but in vain.
22-11-2005, 03:02 PM
I tried to play directly from both xine and kaffeine player but i got this error
xine: couldn't find demux for >/media/cdrom/mpegav/avseq01.dat<
Where can i find the demuxer for this?
22-11-2005, 07:26 PM
#20 (permalink)
Thanks, but i didnt find the "MRL" tab in the setup window.
The solution requires typing ".dat" extension in the "MRL" tab.
Now i got problem with the mplayer.
I upgraded existing mplayer-0.99 to mplayer-1.0 and then it didnt work as i expected. So i uninstalled. Now i am trying to install mplayer-1.0, but i am getting a message that mplayer-1.0 is already installed.
What can be done to this?
24-11-2005, 07:41 AM
#21 (permalink)
run xine-check as local user,For Xine,if /usrsr/lib/xine/plugins/1.0.1/xineplug_inp_vcd.so is there,then it can play dat files.i too dont have mrl browser for adding .dat extensions...will come with a solution....
mplayer-did u removed it as rpm -e mplayer* ?also remove the accompanying packages come with mplayer same version number....like..
mencoder,
25-11-2005, 02:06 PM
#22 (permalink)
The plugin you mentioned is here, but still i get the error about "no demuxer" for so and so file.
mplayer - Where does the files, when we install it through rpm, will be installed?
25-11-2005, 06:21 PM
#23 (permalink)
Generally /opt is used to install apps like real player etc.
25-11-2005, 09:26 PM
#24 (permalink)
I checked that folder but didnt find anything in it.
25-11-2005, 09:40 PM
#25 (permalink)
usually on the /usr folder. The libraries will be placed under /usr/lib and the executables on /usr/bin. For a complete look open the rpm file with file-roller (popularly known as Archive Manager).
