Old 29-10-2005, 06:03 PM   #1 (permalink)
vignesh's Avatar
Default fat trouble.
When I delete files on a fat partition from FC4,it doesn`t actually delete them.When I boot into Windows I find a folder named Trash.vignesh and even the free space never increases.The same happened in Ubuntu only thing the deleted files were in that folder.So I deleted from Windows.How to delete the files fully in Linux ?
vignesh is offline
Old 29-10-2005, 07:37 PM   #2 (permalink)
vignesh's Avatar
Default Login trouble
Now I have another problem not able to login as a normal user.It says your last session only lasted less than 10 seconds.Login in Failsafe terminal and fix the problem.I had chanaged some file permisions.Now I changed them back but still no luck.
vignesh is offline
Old 29-10-2005, 08:30 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
In linux try to also delete files from Trash can, then they will be permanently removed from HDD and windows will not show them.
Or delete the files in linux permanently using either Shift + Delete.
I too faced the ERROR of last session in SUSE linux once! when i tried to change group permissions for the user.
But don't know the solution for it...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-10-2005, 10:09 PM   #4 (permalink)
vignesh's Avatar
I did delete them from the trash can once and another time using shift+delete.
the last session, I made the / filesystem`s permission as 777 (all can read and all can write) .Then I get an error saying can`t write .gconf to home directory.I tried changing home dir permissions , still no luck.
The root login works perfectly though..
vignesh is offline
Old 29-10-2005, 10:29 PM   #5 (permalink)
By default, normal users cannot write to mounted directories, you will need to change the line corresponding to the drive in /etc/fstab, and add "umask=000" to the fourth column (where "defaults" is usually present).
Also, setting permissions of / to 777 is extremely dangerous, you need not use such extreme measures
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 29-10-2005, 10:34 PM   #6 (permalink)
vignesh's Avatar
The umask=000 is what is present by default in Ubuntu.
I just set the permissions of / to 777 to see if it works.Anyway mine a standalone home pc and I don`t even use Linux to connect to the internet.
So any other Solution to the second problem ?
vignesh is offline
Old 29-10-2005, 10:37 PM   #7 (permalink)
Are you able to delete files from your windows partitions from the command line? Try running "rm /path/to/file" and see whether any error comes.
ujjwal is offline
Old 29-10-2005, 10:40 PM   #8 (permalink)
vignesh's Avatar
There is no error.The files get deleted but it doesn`t actually delete them.When I boot into Windows I find a folder named Trash.vignesh and even the free space never increases.The same happened in Ubuntu only thing the deleted files were in that folder.So I deleted from Windows
vignesh is offline
Old 30-10-2005, 12:42 AM   #9 (permalink)
sba
That is gnome-vfs for you.
http://lists.freedesktop.org/archive...st/004539.html
Going by the Ubuntu FAQ
(http://www.ubuntulinux.org/support/d...Using%20Ubuntu)
there seems to be a "trashapplet". You need to click on that applet and empty trash.
sba is offline
Old 30-10-2005, 07:36 AM   #10 (permalink)
vignesh's Avatar
Now I get an GDM error to the login problem...
vignesh is offline
