Hello Friends! I'm using slackware linux. I've been using linux for sometime and am comfortable using it but my level of knowledge in linux is not too high, Though I was successfully able to install slackware on my computer after 3-4 tries. I got it running. But, I've had some problem since. The main one has been with my CDWriter and ComboDrive. They fail to write CD's properly using K3B. I tried using NeroLinux 2.0.0.3. While staeting it up it shows 2 error messages.
1) It says that my cd drives are using ide-cdrom drivers this is not useable with cd/dvd writers. It suggests that I need to install ide-scsi drivers for the drives. How do i go about doing that?
2)It also says that DMA acceleration is currently disabled for both the drives. Though i'm able to temporarily able to turn on DMA by using the following command "hdparm -d 1 /dev/hd*". It last only until I reboot my system. How, do I turn DMA on by itself at startup everytime.
The CDWriter drive is from LG and ComboDrive is from Samsung, if this information is needed.
Please help me out here as i'm unable to find the solution here. If its been posted previously point me to the link.
