Old 20-10-2005, 11:45 PM   #1 (permalink)
Default need little help in FC4
guys
i've installed FC4 and i want to mount my ntfs partitions on that.
By searching in the forum i found that i have to install a rpm for the ntfs partition . So i downloaded the rpm which is ntfsprogs-1.12.1-1.i586.rpm and installed it properly.
i've createsd the folders according to drives like /mnt/c,/mnt/d etc..
but i don't know the line to be written in the /etc/fstab
please someone help me out in this one ........
shrohit is offline
Old 21-10-2005, 02:33 AM   #2 (permalink)
desertwind's Avatar
append the line in /etc/fstab
/dev/hda1 /mnt/c ntfs ro,defaults,umask=0222 0 0
provided /dev/hda1 is ur ntfs drive and /mnt/c is the directory where you are gonna mount it.
I found this website very useful, if you want a detailed tutorial.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 21-10-2005, 03:19 PM   #3 (permalink)
vignesh's Avatar
Remember you cant write onto an nfts partition.
vignesh is offline
