Old 20-10-2005, 12:52 PM   #1 (permalink)
champ_rock
champ_rock's Avatar
Default Damn Small Linux
hi i wanted to know which desktop managwers (kde etc) does Damn small linux use.....
its very light on my resources.............
Registered Linux user number 400618
champ_rock is offline
Old 20-10-2005, 02:40 PM   #2 (permalink)
Fluxbox
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 21-10-2005, 03:22 PM   #3 (permalink)
vignesh's Avatar
YA its very light.By the way KDE is a desktop enviroment and fluxbox is a window manager.Am I right ujjwal ?
vignesh is offline
Old 21-10-2005, 04:35 PM   #4 (permalink)
champ_rock
champ_rock's Avatar
ok thanks because i installed some light ones which could not do a single thing......
Old 21-10-2005, 09:01 PM   #5 (permalink)
Well the lighter window managers like Fluxbox/Blackbox tend to be a little minimalistic, but they are very powerful, and with proper knowledge, they can be used to save some time and effort. You could also try others like IceWM or FVWM95, which provide a fast windows 95 like interface. Or you could choose the middle path and go for something like XFCE
Vignesh, yes, KDE is a desktop environment, which provides other extra features like icons, file manager, applications in addition to its window manager.
ujjwal is offline
Old 21-10-2005, 09:39 PM   #6 (permalink)
Satissh S's Avatar
I like Enlightment, It's light on resources but is extremely powerful and visually appealing too. It has tons of space on desktop so i can use the Gimp more effectively.
Iam not Exaggerating anything but use it and see the difference.
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 22-10-2005, 10:12 AM   #7 (permalink)
vignesh's Avatar
Once we have installed the window manager(s) how to use them or switch between them.Which file do I have to edit ?
vignesh is offline
Old 22-10-2005, 10:47 AM   #8 (permalink)
To change the default window manager for the current user, edit or create the X initialisation file called .xinitrc in your home directory and add the commands to start your window manager, for example
#!/bin/sh
exec icewm-session
The commands will vary across different window managers, reading the man page or the software's documentation is a good idea.
ujjwal is offline
